Any ideas where I can get one of these for my '56 ES2 - they seem to be unobtainable under £400!
Hardly anyone will sell re…
.. There are electronic ve…
.. There are electronic versions that have identical faces. Not cheap but cheaper...andavailable. Made by ex-Smiths employees apparently.
...but unless it's progra…
...but unless it's programmed for a Norton single, an electronic version won't have that 'one, two, three, tick' movement of a proper chrono...
Someone on the 'Real Classic' pages used the term 'cadence' when referring to big singles and it applies to chronometrics too. They are a small, but essential part of that 1930s - 1960 motorcycling experience.
A pseudo-chronometric need…
A pseudo-chronometric needle movement is optional. My 88 ss hss no rev counter so one of these is on my wish list.
Smiths 120 mph chrono in w…
Smiths 120 mph chrono in working order (He said) at Rufforth AJ today (Saturday) £200.
You can now buy a new Smithselectronic replica for just a bit more.
Thanks for the help - the…
Thanks for the help - the electronic replacements wont work with 6 volt unfortunately. Can anyone tell me if the Hitchcoks ones are a straight replacement and match the ratio of the drive?
Just run a low power 6VDC…
Just run a low power 6VDC to 12VDC converter. It's going to need mA not A. Only a few pounds each, available from a wide range of places.
Hardly anyone will sell reconditioned chronometrics outright. The UK price for an exchanged recon. instrument is around £180 - £200. Virtually any version can be exchanged...the art therefore is to find a scruffy but rebuildable donor for not too much money - it doesn't usually have to be same speed range or with trip etc.
I'm not sure though if they will accept 'D' shape...at one time some repairers did. I don't see you getting away with less than about £300 in total though.
