petrol taps again
My ES2 is fitted with lever operated ball valve petrol cocks. Problem is that one of them leaks through the operating spindle. Any advice on a good quality tap that will fit the bike? Cheers, Georgeps I've checked previous threads and not found anything constructive.
Hey George, have a flick through the N.O.C. shop, (type 'TAPS' in the search box) they cover a fewstylesat very good prices. If you are not too fussed with originality, the lever Triumph style work well, I have a couple on my Bonny and have no problems.....well, not so far anyway! ;)
Thanks Ian. It was not so much the source I was after, more the type as I gather that taps from a certain country tend to leak. I like the idea of "ethanol proof" but am not sure of the advantages of push-pull (as the original) or lever type. George
I have fitted BAP taps tothree British motorcycles. Not original style, but I was fed up with leaks starting soon after fitting original types, and these do at least seem to me to have an oldish look about them. None have leaked in the several years that I have been using them, and they are relatively cheap. Only problem is that the metal is not very strong and I snapped the thread which screws into the tank on one of them but it came out easily; OK now I know better than to swing on the spanner.
I think that they are all 1/4" BSP (?) inlet and outlet.
Thanks Richard. That's what I need to know. I notice that taps are notated as "main" or "reserve" yet the two on my bike are exactly the same. What's that all about? George
Having thought about the "main" and "reserve" query I now see that they could be handed. My bike has two exactly the same as the lever can rotate through 360deg. G
The "main" tap will have a stack pipe on it allowing an amount of fuel to be left below the pipe for reserve. The "reserve" tap will drain down the tank to the bottom. Bare in mind that you might still have inaccessible fuel below the the stack pipe on the "main" side unless both sides of your tank are interconnected. (unlikely) I fit both sides with taps that drain down to the bottom. My reserve is supplied by what is left in the "saddle" on one side. Nothing worse than running out and having inaccessible fuel on one side
That's what I have David. Both taps the same and the reserve is what is left on the right hand side (about 2 litres or 26 miles - max). I think I'll stick with this idea. As you say inaccessible fule is useless - a bit like runway behind an aircraft. Cheers - George
I agree about having 2 main type taps. I 'ran out' one day when I hadold type reserve andmain taps on my Commando. Looked in the tank and there was quite a bit left on the main side but I was unable to slosh it over to the reserve side.
Both my BAP taps on all machines are now reserve type. As has been stated the main type has a short pipe inside the filter. The filter is a plastic fitting which just screws in place and can easily be removed from a main tap and the pipe pulled off to convert main to reserve, so you can buy either type.
Thanks for that info, Richard. I've now ordered a "reserve" BAP tap from Feked. I find that the NOC Spares take too long to arrive. Very grateful for all your input. George
Hope it works OK for you, you might find it useful to wrap a few turns of PTFE tape around the thread which goes into the tank. And don't forget to go easy on the locknut !
For me, Loctite thread sealant works better than PTFE tape. Makes it easier to position the tap in the direction I want without excessive force. On old tanks where the flanges is in bad shape the usual fibre gaskets are useless.
I suppose it depends on one's physique, but I find it quite easy to lay my Commando on its LH footrest and then get the wheels in the air to persuade the unused "main" fuel over to the other side -- call me a nervous Nellie, but I like to have a reserve to the reserve.
p.s. also easy to get the Commando back on its wheels; this bit is important ...
