ES2 performance
I've been playing with my ES2 today as I wasn't happy with the performance; it went flat at about 55 in top and wouldnât pull past this speed. After a conversation with Mike Pemberton I checked and altered my valve timing, I now have the inlet opening 27BTDC and the exhaust closing 32ATDC. I know the exhaust is a little later than ideal but itâs as close as I can get it with the standard cams and gears. Ignition timing is 5/8BTDC fully advanced.
Based on one of Mikeâs articles in Roadholder it should be capable of 53 in 2nd, 71 in 3rd and 82 in top. Now I can't really afford to rebuild the engine again so I was being a little sympathetic, but I still got about 50 in second and about 65 in 3rd. All was going well until I changed into top, it just sat at 65 and offered no further acceleration, I can slow down to about 30 and accelerate back up to 65 without changing down, so its pulling top gear with no trouble at the lower revs.
A few sums and the top speeds in each gear equate to about the following RPM:
50 in second - 4760RPM
65 in third - 4230RPM
65 in top - 3496RPM
I'd expect it to rev a little less in each gear as you go up, but why the sudden lack of acceleration in top?
I have a 21T engine sprocket which is one above standard, all the other sprockets are as original.
It's on a pre-monoblock 276 carb with a 160 main jet. I played with this a few weeks ago and found that to be the best size, maybe I need another look now I have altered other things?
I have a 16H piston in it giving about 8.2:1 compression.
I know the valves seats are quite badly recessed up into the head and I plan to take the head off over the winter and get new valve seats fitted, but would that make this big a difference?
Anything else I have overlooked? Anyone experienced these symptoms before and able to offer any help? My last trip round the block to try it out saw the speedo tick over the 3000 miles since Iâve had the bike on the road (about 18months), so Iâd like to get it sorted now, Iâm getting a little tired of seeing this one up on the bench!
Thanks in anticipation
Andy
Andy, I'm not surprised. The main jet should be 270 and while you are about it, the slide should be No 4.
Hope these changes improve things significantly.
PS: 276? I was working on a 376 or even a Mk1 consentric.
Hi Neil
I should have said, it's a 1951 iron engine. They had 276s on them until 1954. The manual and Burlens website both show that it should be a 160 main, this ties in with what Martin Bratby fitted when he overhauled the carb for me. When they went over to the monoblock they used a 270 mainjet, but arent the two carbs completely different? Therefore jetting would be different. Plus the plug shows no signs of running week...
I do have some bigger main jets but last time I played with jets I ended up back at a 160, I'll try again now I have sorted the valve timing.
Andy
I would have expected the engine to reach max revs in both second and third gears. Then drop a fair amount in top. The figures suggested to me that this bike was slightly overgeared and under carb'd. Talking with some of our older and wiser members with big singles. They say that, back in the 50s, cruising at 55mph was the norm on a bike such as the ES2 as the poor roads surfaces and iffy bike suspension did not help to achieve faster speeds that were safe.
Checkout the attached info about sprockets and carbs. If I was trying to get more go out of an old ES2 I would be definitely fitting the 376 carb and possibly changing the gearing.
technical1-si
Thanks Phil. I am reluctant to fit a monobloc carb as I'd like to keep it looking origonal... Would a pre-monobloc 289 offer simmilar improvement? Carburation is all still a bit of a mystery to me, but I am learning!
When I was talking to Mike Pemberton last week he reckoned the extra tooth on the engine sprocket shouldnt present any problems at all. However I do havea 20T engine sprocket I can try on it so I'll try that next.
Thanks for the help
Andy
I've had another look at the carb just now and where it has the gauze filter on the end I noticed there where 3 layers in it and you could hardly see daylight through them. I have taken 2 out and run it down the road, it is noticably sharper low down but hasnt really effected the top speed. A check of the plug shows its now running very week on the main jet. I have tried going up to a 180 main but it is still rather week. I don't have anything bigger so will have to order a couple more jets and try again.
Has anyone experienced problems with these gauzes restricting the flow significantly in the past?
Andy
65 in top - 3496RPM
Andy hi andy,had same trouble with bsa b1 ages ago,did everything like you and decided motot was very tired,began strip to find bore very good,checked head and found exhuast valve to be quarter inch shorter than standed,fitted new terry springs and refurbished head and the bike goes better than ever,also,go down one tooth from standard on engine sprocket and go up one on gearbox ,no affect really on top speed but you will have much perkier accelleration especially in wind and up hills,regards,bruce,australia.p.s.my 16H norton is in march copy of roadholder.
Hi Bruce
I know my valve seats are very recessed into the head so Mike Pemberton is going to do them from me over the winter, other than that the engine is all fairly new and in good condition.
To my understanding, going down a tooth on the engine and up a tooth on the gearbox would basically cancel each other out... Why would it make a difference? I'll give it a go, but am interested to learn why it works.
Thanks for the reply
Andy
Go back to a 20T engine sprocket. Even over-gearing by 5% can result in the bike being no faster in top than in 3rd. You may just be surprised...
The 276, and the the monoblock used the same type of jets, and were the same bore. There is a vast difference between 160, and the 270 jets recommended for the monoblock. Has a typo crept in somewhere? In the 50's, before I got a Dominator 88, I cruised at over 60 m.p.h. on a rigid rear B31. The roads were probably better then than today, and, there was far less traffic (and no maximum speed limit on unrestricted roads). 55 m.p.h. cruising speed Phil, who have you been talking to? I used to average over 50 m.p.h., between Blackpool and S.E. London (before there were any motorways).
Are you sure about the jets John? Quite different in my similarly equipped bikes. My MSS Velo has a sweet spot at 58mph with plenty more if required - an ES2 should be similar in performance. It can take a fair bit of trial and error to get the carb set up properly and that can make a remarkable difference.
I'm pretty sure the jets changed for the monoblock. If you look at 276s fitted to other 500 singles (bsa, velo etc) they are all around the 160-180 area so im pretty sure thats right.
I took one of the layers of gauze out the flame trap on the carb and had to go up 4 mainjet sizes and lift the needle a notch to get the mixture right again! I still have 2 layers on there but no more main jets at the moment to keep experimenting.
I'll put the 20T back on and see how I get on.
Thanks again
Andy
Your overgeared. Also if the valves are sunk this will not help. If you have 23bhp I would be suprised. If you want to go faster and want a Norton go for a twin. You will spend a lot of money making a single ES2 keep up with a twin Andy.
My poor man's Manx (59 ES2 in a wideline) runs a 22 tooth engine sprocket and 20 tooth gearbox sprocket.
Pulls away fine though acceleration is slightly sluggish but 60 mph cruising is very relaxed with plenty more on tap. I use a 30mmMk 1 Amal, though I have seen these machines with 34mmMk2's.
3 1/2 slide and currently 230 main jet with plug a perfect light brown colour. Seems to me that the bigger the carb the smaller the main jet and lower number slide? Sounds logical at least. Oh, andGoldstar type exhaust system too!
I put the 20T back on and not gained any speed. It just sounds like im thrashing it at anything over 60. It does pull better on the hills though so I'll leave it as it is for the rest of the season.
I have a 289 carb (still pre-monoblock but bigger bore) to put on and I'll get the valve seats sorted and open up the inlet to suit the carb, but that can wait for the winter.
I am not trying to get my ES2 to go like a twin, but I would like it to go as well as an ES2 should, I have a mate with a model 18 who just leaves me for dust! Only difference I canfind between the two bikes is that he has a brooklands can instead of the standard silencer.
I'm beggining to think I am chasing my tail until I get the valve seats sorted!
Neil: Thats very high gearing... Are there any other mods or just the carb and exhaust? Are you on standard cams etc?
Thanks again
Andy
Sorry for the delay, Andy. Other tan the high gearing, Goldstar pipes and 30mm Mk 1 Amal, that's about it.
The bore was on +60 and well worn, I tried it with new rings but it was too far gone and using oil. A mate made me a sleeve and I went for an AP piston (79mm) from RGM. A good quality piston but I should have realised it was a bit heavier than original. Even so it is reasonably smooth, no real vibration but slightly lumpy. I still like it.
My ES2 on the other hand is 530cc using a 28mm Mk 1 Amal. The gearbox sprocket is 20 tooth but otherwise everything is standard, as on the PMM. They both go well on BP Ultimate and a bit of RedX lead replacement and a dash of castor, just for the aroma!!!!!!
Just as an update - After saying I was going to leave it alone untill the winter, I had a spare afternoon yesterday so decided to try putting the brooklands can from my Inter on the ES2 to test the idea that the standard exhaust could be choking it. I went for a quick test ride and although I have no more top speed, I had a lot more low down 'grunt'. I went back up to the 21T engine sprocket and again, its not really any faster but it is pulling better lower down the rev range. It also made it run weaker so I have gone up a main jet size (I have no idea what all this means in the grand scheme of things, but its obviously made a difference)
Its more comfortable at 55-60mph now (appart from the noise!) So now I really will leave it alone until the winter when I plan to fit a bigger carb, open up the inlet to suit and have the valve seats done. I am also tempted to splash out on a set of Mike Pembertons cams just to really get the best out of it.
Thanks again for the advice
Andy
Andy
Hi Andy .... Recognising that this is a fairly old thread, I'm just wondering how it all ended? Did the head work get performance to where it should be?
Ta
Hi Philip
Mike Pemberton did the head, new valves, guides and seats. He opened the inlet up to fit a 1 5/32 carb and I fitted a set of his cams. I rode it to Italy and back for the international rally there with this set up. It goes incredibly well now and I think I am finally getting to the point where I am happy with it. It's got quite a lot of other mods on it now to make it a more usable bike.
I have picked up a later 8'' single sided front hub for it which I'll get built up and in ready for this summer so hopefully it will stop as well then.
Are you working on one yourself?
Andy
Andy
Just had the Model 18 for a few weeks now. Good compression, starts first kick, runs and sounds lovely, but definitely not quite right as it just about hits 55 mph and feels like it has more torque but no more power than my Tiger Cub. Ignition timing is good and valve timing appears good, although I'm measuring in terms of distance bTDC rather than with a degree wheel. But I'm sure they're not far out. I've put new petrol in - no idea how old it was - and new spark plug goes in tomorrow. I'll then see how the plug looks during a "fast" run. If those don't solve it then a carb strip down seems to be the next step but the main jet seemed clean when I undid it yesterday.
Fingers crossed.
Phil
