Hi, I acquired this basket case yesterday which although complete does have me scratching my head somewhat. The engine is a 600cc single, I believe Big 4, with number 90440. I have been unable to locate a frame number so far which I'm told should be on the headstock? The gearbox is a dolls head. Not sure if this is a bitsa basket case or what it is. Forgive my complete ignorance of old singles but any advice will be appreciated. Thanks Paul.
bike-png
Hi Paul, look for the fram…
Hi Ian, thank you. I've h…
Hi Ian,
thank you. I've had a gentle sand in the area you suggested and you're absolutely right. I can make out the letter A (I think) and a number which at present looks like 88118 but very hard to say. I believe, if this is correct, it should be a 1946 Big 4 Plunger. The bikes a rigid so I best keep sanding away!! Many thanks. Paul.
This frame is an 'open di…
This frame is an 'open diamond' and all post-war frames with the exception of the 500T (which this doesn't look like) were full cradle. If it has horizontal saddle spring lugs then it is a pre-war (civilian) frame dating from late 1936 - late 1939.
The left hand side of the front fuel tank lug is the only correct place for the frame number. Perhaps better to wire brush than to sand - it doesn't help if the casting marks are removed from the lug. The numbers were not always stamped very hard.
Image below came from the net somewhere but shows a pre-war number.
90009-jpg
I find the photo Richard p…
I find the photo Richard posted interesting. My 38 ES2 also has the 5 above the frame number..what is the significance of the Number 5
I'm not exactly sure, Ian…
I'm not exactly sure, Ian. WD frames don't have it (even pre-war ones) so I haven't investigated but I believe it's been discussed on here before.
My impression was that it must be related to frame type (for stores identification) rather than model type. Apart from the 350s, all the models were mixed up amongst themselves.
There doesn't seem to be anything in the factory records which show a definite correlation.
I must confess that I hadn…
I must confess that I hadn't noticed that the pre-war frames lack a model code. My '37 CS1 has a number above the frame number but it isn't clearly stamped. I had assumed it was a model number. Looking again it could also be 5, as per Richard's photo. I should have realised that Bacon does not list a single letter code for CS1 in "Norton Singles" . Also, the 5 code appears not to be associated with a specific model. It looks like the frame number series was repeated post-war so Richard's example could have been re-used somewhere around '60/'61 (again according to Bacon).
ian McD
For reasons I can only put…
For reasons I can only put down to age I've just read my original post and realised I said Big 4 engine when in actual fact I should have said model 19 engine number 90440. There is no model code on it that I can see. Sorry for causing confusion. I haven't had chance to explore the frame number further but intend to do so this weekend. I will also get a photo of the seat lugs Richard. Thanks for everyone's comments.
If the Model 19 engine fit…
If the Model 19 engine fits in then it's not a WD16H frame and could well be of the correct type. According to the late Peter Roydhouse, the OHV 600cc engine was the only one that was too tall to fit into the high-ground clearance WD frame.
What does seem likely is that you have a pre-war frame fitted with post-war tele forks. Some would regard that as reducing period charm, others as a worthwhile improvement. The choice is yours, but Norton girders are not that easy to find any more and are expensive...I would certainly steer clear of the Indian copies with their apparent cast-iron lugs and inaccurate jigging.
Another approach might be…
Another approach might be to regard this period upgrade as simply another type of period charm (and interest: I for one would not attempt to reverse one of those post-war bolt-on swinging arm conversions, since they too are a significant part of motorcycling history).
For comparison, in 60 years' time what will our successors make of all those Commandos with twin floating discs?
What does seem likely is that you have a pre-war frame fitted with post-war tele forks. Some would regard that as reducing period charm, others as a worthwhile improvement. The choice is yours, but Norton girders are not that easy to find any more and are expensive...I would certainly stear clear of the Indian copies with their apparent cast-iron lugs and inaccurate jigging.
Hi, the frame number appea…
the frame number appears to be 98118. I haven't located any letters or other numbers such as the 5 mentioned and shown in the photo above. The frame is pitted in this area so it's tricky and going to take time. I believe this is likely to be a 1947ish Model 19 frame?
I understand the 19R was a rigid with Roadholder forks but only manufactured in 1955? I find this confusing as I saw one for sale on the net that purported to be a 1948 19R?
I don't have a problem with a mix n match bike but In all honesty I think I've bitten off more than I can chew with this one restoration wise.
Thank you to everyone for the help.
According to Bacon, there…
According to Bacon, there were no Model 19s between 1939 and 1954 (when it was the 19R and 19S).
Have a talk with the Club…
Have a talk with the Club Record Officer. He can check against the factory records database quite easily.
I only have copies of pages which include WD entries and not all of those are easy to read. The entries are a long way off consecutive order - sometimes three or four thousand apart on the same page...but I can confirm that frames 98102, 98103 and 98106 were all 1939 model year Model 19s despatched during late 1938.
The engine number could well be correct for the frame.
If it is a 1939 Model 19 with correct engine for year then it's certainly worth doing. Gorgeous.
img_1590-2-jpg
For the avoidance of doubt…
For the avoidance of doubt presumably Model 19s is the plural of Model 19 whilst Model 19S is the actual model type. I mention incase any readers are not familiar with the model types.
George
Previously paul_dudill wro…
What?? Come on Paul, you're not supposed to get disillusioned until you've spent at least £4000 and every weekend and evening over three years on it! Never say die, up man and try. We're all here to help!
I agree with Adam. I've j…
I agree with Adam. I've just spent the last month or so (and a ton of GBP's) dismantling and "re-mantlling" my gearbox and clutch in an effort to get better gear changes. It all now finally works.
The triumph of Perseverance over Ability!
And this message board is here to help.
George
Thank you for the help eve…
Thank you for the help everyone. I've sent off a request for a records check and will update once I have some news. As I said the frame number is difficult to read so please be patient. In a former profession we used a chemical agent to reveal frame/engine numbers that had been messed with so I may need to resort to that. I'm not suggesting the number's been messed with just that due to pitting it's difficult to be definitive. Paul.
Previously George Phillips…
George
I feel your pain George, and I havenât started on the AMC box yet!
Happy days, everything is…
Happy days, everything is in order, it's a late 1938 model 19. Thank you everyone for your help. Paul.
Hi Paul, look for the frame number on the front petrol tank lug, LHS. There should be model number plus serial number. Post war there is also a date letter and the frame & engine numbers would have matched when they left the factory. Pre war frame & engine numbers didn't match. Date code started with A in 1946 and ran through to R in 1960. Big 4 model code is 7. Example: C7 xxxxx would be a 1948 Big 4.
Dolls head gearbox suggests an earlier bike (late 30s - early 40s) but tele forks came in around '47 so possibly a bitsa.
Cheers, Ian McD
