Hi all,
Does anyone know of a source for these? I have emailed and phoned pretty much anyone who lists Norton parts and drawn a complete blank in the UK.
I can get those that fit the clutch basket but critically NOT for the clutch plates for my laydown 'box. Bonded linings are out, i have tried them in other bikesand useless does not even being to cover what I think of them.
James
James Have you tried Bob M…
Hi all, Ron, tried as you…
Hi all,
Ron, tried as you suggest but he does not supply the parts.
It's now been NINE MONTHS since I started trying to find replacement inserts and guess what? STILL looking. I can't even get bonded plates to fit the Laydown box clutch, EVERY supplier I have asked has said the same thing 'Don't keep them'.
It seems that if it is not a featherbed based bike or a Commando you CANNOT get parts. Some I have been looking for for over 18 months and despite dozens of emails and phone calls NOTHING I have trawled every bike show I have been to and asked the traders NOTHING.
In case you are thinking I am after rare parts all I want are the small fittings for an ES2/Model 7(1955) and the response from most companies is 'Don't do parts for them'
Not a good advert for Norton is it?
I don't quite understand…
I don't quite understand the aversion to bonded plates unless it's from an originality point of view. Perhaps you've had bad luck with previous suppliers ?
Have you thought about trying Ken McIntosh in NZ ? He lists parts for pre-1956 clutches. I have his bonded linings in my 16H and clutch action is very good. The 16H won't be taxing the grip but Ken's Manxes would.
http://www.manxnorton.co.nz/catalogue/;jsessionid=408A561034DFF8AA48A6B5D48257D24A
He also makes top quality dull chromed fittings for the rigid and plunger models.
Postage from NZ is not expensive.
Richard, Thanks for the in…
Richard,
Thanks for the info but there would be import duty on those prices, I don't buy from overseas anymore because of this nor do I buy repro parts because they never fit and are getting worse. Bonded plates would be an absolute last resort and I mean that because THEY SLIP LIKE MAD while the original type DON'T.
If I am honest I am sick and tired of chasing round suppliers who are unhelpful and try to sell me sub standard parts (repro crap) while claiming they are better that original. So far the few repro parts I have bought for other projects have been utter rubbish and have had to be modified in some cases drastically to make them fit while others have been returned as not fit for purpose and before you all think it is me others have tried and could not get them to fit either.
The only repro part I have bought that was any good was a gearbox layshaft that had to be specially made because replacements basically don't exist because certain people hang on to them rather than letting people who are trying to restore bikes and actually need them.
There is indeed usually im…
There is indeed usually import duty levied on parts from NZ but bearing in mind the exchange rates and the low postage cost, I've found it not overly expensive.
You're running a bike that probably hasn't had 'genuine' parts made for it since Nortons left Bracebridge Street so pretty well anything is going to be 'pattern'
In my experience, if one can utilise parts made for the racing boys (which is what McIntosh's Manx stuff is) then it's not really correct to compare it with autojumble 'made to a price, who knows where' stuff.
I'm using McIntosh's matched springs and modified cups also and the clutch is light, lifts cleanly with no trace of drag and certainly doesn't slip.
I suspect many of us have a bit of the hoarding instinct. As parts become harder to find, there's always the thought that I 'might need it one day'.
Richard, I know these part…
Richard,
I know these parts haven't been made for a long while but I would at least expect to get even bad quality parts to replace the worn out originals. The second I say 'single down tube swing arm frame' or 'Model 7' to any supplier the instant response is 'Don't cater for them'.
The bike list that used this frame is as follows;
Model 7
ES2
19S
Model 50
Model 77
I find it EXTREMELY hard to believe that there is NO supplier for spares given the 7 year run when it was made I also find it stupid that suppliers don't doBASIC SPARES to keep or in the case of mineTO EVEN GET THE THING ON THE ROAD IN THE FIRST PLACE.
Another round of phone calls this morning yielded NOTHING.
Its getting to the stage I may as well take a gas axe to them because they can't be resurrected.
The lack of a specialist s…
The lack of a specialist supplier for older 'non-exotic' Nortons is a bit of a puzzle. Norton were though always a relatively small factory. We used to have Dragon Motorcycles but they're long gone and the stock frittered away by Bantam John without any apparent attempt to replenish it.
Even things like head bearing cups for rigids have become difficult.
It would be so nice to have a Norton equivalent of 'Draganfly' actually watching the market's needs and commissioning as necessary.
Perhaps 'we' are to blame for not wearing them out fast enough (but of course we don't dare to because we can't get the parts...)
I'll say this much SCOTT…
I'll say this much SCOTT HAVE BETTER SPARES BACKUP THAN NORTON and they are notoriously bad BUT there is a jungle telegraph within the club and if you want a part just put the word out and they usually turn up unlike this one that does very little it seems. The Scott club are apparently getting new cylinder blocks cast at some point as well as having new close ratio gearbox parts made, I see nothing remotely like this being done by the NOC.There are NO suppliers of Scott parts apart from the club (except a few members)AND THIS MARQUE IS FAR SMALLER THEN NORTON YET PARTS ARE AVAILABLE!!!
maybee its the decepid , o…
maybee its the decepid , old, dodgy memory, but didnt the old- boys use cork tiles and cut them out to size with a stanley knife?
regards eddie
I've also heard tell of o…
I've also heard tell of owners using the corks from crown tops off beer bottles for the job.
James
Have you tried Bob Metson on 01273 494437? He can recork plates and sprockets for £9 per item.
Regards Ron
