Speedo mount
hi guy im wondering if eny one can help im trying to find the rubber suround that gose in the headlight that the speedo sits in to im also after the primary casing nut this is all for my dominater
Hi Chris
Ideally what you need is a 80mm diameter, 3mm section 'o' ring. Try your local bearing supplier or alternatively you can buy a length of 3mm section neoprene/rubber off eBay and cut to suit, joining the ends with glue. That's what I did anyway - not concourse but a neat, watertight seal. Hope this helps.
Try Ashley Popel at Speedo Repairs as he supplies these Speedo O rings when he rebuilds Chronometric Speedo's. He supplied me with one when he rebuilt the Speedo for my Norton Manxman. He advertizes in Roadholder.
