Speedo drive
Hi
I have recently had my speedometer refurbished, and I now need to sort out the speedo gearbox. I have been unable to find out the name of the part that holds the speedo cable in the drive (metal/brass? bit, attached). It needs replacing, but I am unsure whether I can source it as an individual part, of if I need to buy a whole new gearbox. I have gone through catalogues in the regular online shops, but no luck.
Thanks all
for your input
IsaakPS: moderators, is there an option to be able to swiftly search through older posts? It seems like a good improvement, to avoid duplicate posts and to help Norton owners to find answers to their queries in a speedy way.Yes - it's been there all the time and just a few inches away on your screen. Look to your top right and find the Search facilityWebmasterAttachments
I'm pretty certain you'll have to buy the whole thing - try Burton Bike Bits or RGM.
Regards.
Ian.
Try Gaggs as they have a huge supply of speedo drive gearbox's, revcounter drives, as well as all the cables that would be required for all Norton models.
I had never heard of Gaggs (being an American), so I "Googled" them & found a great write up about them! I will get ahold of them to see if they rebuild the whole speedometer gearbox, or just sell replacements. No one "over here" seems to know how to repair them.
http://www.totalbikebits.com/tbb_classics/featured_dealer/featured_dealer.htm
Painting sparrows yellow to look like canaries, I though that kinda stuff only happened over here! :)
Skip
Thank you for reminding me about Gagg. I was a student in Nottingham in the early 1970s, and I remember the shop now. I just emailed them with regard to my Electra speedo and drive.
For Isaak, I think Norvil do a part exchange service on speedometer drives, check their website. I did get a rebuilt rev counter drive for my 650 from them about 10 years ago.
I have some broken speedo drives that i will not throw away in case one day they can be fixed. Unfortunatly i have never found any one that can repair them. I live in hope, but until i can get my old ones repaired i have had to buy new ones. Sad but true. I have asked Gagg's of Nottingham, and they can not repair them, so this is where i have bought all my new ones.
Thanks all! I'll check those sources you mention. As I said, just had my speedo refurbished by Richfield and Im looking forward to being able to try it. To finally see how fast I can actually cruise on these British roads!
I
Just contacted Gaggs. They do not supply that part, and they could not reccommend (obviously, I guess) an alternative source. "We canonly supply new speedo drive = £50.00
Annoying having to buy a new one, just because of one small brass piece. Should have listened to you, anthony_curzon.
Isaak:
I believe that the item you have posted the photos about is a brass fitting/bushing that is a press fit into the speedo drive housing. I have never heard of it being sold separately.
I guess that you could buy an old drive unit with bad gears and remove the old bushing by cutting away the housing and then re-fit it to your housing by pressing it in. But it would be simpler to just get a new drive.
I wonder if the housing & brass piece could be cleaned well, primed with loctite primer, then apply red Loctite & re-assemble?
Nothing to loose?
Skip Brolund
