Tyre rotation
I have just fitted an Avon Roadrunner tyre on the rear of my Dominator 99. I noticed a rotation direction arrow on it which indicates which way it should go on the front. I have presumed the opposite for the rear as this seems the way on other tyres. My question is WHY? The tread pattern issymmetricaland doesn't diver whichever way it goes on.
Don Constable
Cos' on the rear you want max traction under acceleration and on the front max traction during braking.
Be careful! The Roadrunner comes in front only, rear only, and universal types. Check that you are not putting a tyre designed for front fitment on the back.
Alan
What Roadrunner have you fitted ? ie what AM number ? Later Roadrunner's (with higher AM numbers)are front or rear specific ! Make sure your tyre is suitable for REAR fitment. If it is only marked for front direction, your MOT tester may not like it.
Regards, Tim
I used to use the original Roadrunners (I think they are now called "Classic" Roadrunners) on a Commando back in the 1970s/80s. They were 4.10 x 19 front and rear. I used to put the one off the front on the rear when the rear wore out, and put a new one on the front. That way, the front tyres, which wore in a sort of triangular profile, wore flat on the back, and I always had a really good tyre on the front for steering. It also ensured that the front tyre did not die from old age before it was worn out.
Thanks for all your responses.
Tom, I understand what you say, but still cannot see any difference in tread pattern so why the arrows?
Alan/ Tim, Universal - AM9 4.10x19 and is suitable front/rear. Also no MOT in Australia.
Ref Tom's response - yes he is correct - as far as I'm aware it's not to do with tread pattern but tyre carcass stresses.
The belts underneath the rubber are not symetrical. The front has to resist most of the braking force and the rear has to cope with the accelerating force.
Alan
Seems logical! The mighty force of my 99 shouldn't cause too much trouble. Also I found rear rotation arrow, so the local plods should not be worried.
Now to see how it feels. Thanks guys.
Best wishes,
Don
