Rising revs on tickover
Last winter I splashed out on new carbs for my '58 Model 99 and have since covered 600 miles or so with no problems. Last couple of times when I've started it the revs rise as it warms. It does appear to peak, ie get to a point where it stops rising and on the road doesn't cause any real issues. Selecting first is tricky though (read 'embarrasing!). I suspect I've got the old inlet sealing problem but a liberal spray of WD40 when the bike's running doesn't seem to have any effect so I'm not convinced. Both slides rest on their stops and I've not messed with the settings, having managed to get a very respectable tickover after I fitted the new units (eventually!). The cables are all good, not sticking. Can you good people suggest anything else to look at before I take the carbs off and refit them? In case I'm asked, it's distributor and coil ignition. Thanks in advance.
That's normal behaviour. If the revs are too high when it's properly warmed up just back off the throttle stops.
Thankyou both. I know revs rise as the engine warms, but it wasn't doing this until recently. I've always had to hold the throttle open a few minutes until it started getting hot (there are no airslides fitted) but now as soon as it fires I can leave it alone. It's a bit unsettling as it revs its nads off on the drive and starts crabbing towards next doors' car! Just seemed unusual, one day fine and next day this! Before I got the new carbs I'd got so frustrated with it I was going to change to single carb - didn't you sell me a manifold Alan? In the end I went for originality over simplicity which I know can be acontentiouspoint in itself. I'll check the A/R as Robert suggests, the motor is quite well run in at 2000 miles. If that fails, I'll start fiddling with the carb settings but if it gives me too much grief I'll be reaching for that manifold!
Thanks Gordon, but I don't think thats the problem. Its never had airslides in the last 50 years that I can trace its history back to (P.O. 45 years) but if I went for the single carb option I would convert to airslide, as holding it open has always been a pain. There are blanking plugs in the carb tops where the cables would enter and there's no air getting in there. Just to go off track a little, I've often wondered why there are no slides. One chap I spoke to reckoned it was an old racers trick to reduce weight, it would be interesting to know if it was supplied new like this.
I've had a persistent problem like this with a pair of Concentrics. They are very easy to distort. These are new but were left fitted over a period of years and I believe had been overtightened. I had sincefitted gaskets between all the manifold components (heat proof spacer and distance pieces) to try and stop leaks but was told that the gaskets themselves can distort the manifold flange, so have fitted without and with a smear of Wellseal. That seems far better but I think that as the bike stands running, the heat causes the tickover speed to increase and become uneven? I have a feeling that it's the carb bodies acting on the throttle slides? Only an inexpert theory, and subject to comment by those much more knowledgeable than me, but you aren't alone with the problem!
I don't think any were supplied new without airslides. Racers routinely removed them. Something less to clutter up the handlebars. Because the carbs were designed to be used with airslides, I always fit them even if they are pretty much redundant, in summer anyway. A lot to be said for reverting to a single carb - one of the better things I have done to my bike. Take a good look at the A/R springs on the distributor. It does sound as though you may be getting stuck on full advance. Gordon.
Have you checked that the throttle slides are able to bottom. Even with ignition timing stuck, it should be possible to stop the motor with the throttle stops backed out and fully closing the throttles. Is there a little slack in the cables when the throttles are shut? As far as A/R springs are concerned, they are not going to suddenly get tired but they can break. Are you running twin cables from the twist grip? I had the junction box stick once on the 1 into 2 setup. BTW I never use air slides but then I live in the sunny south not up in the Arctic like Gordon.
Are the throttle slide springs strong enough? It might just be that they are not closing the slides sufficiently, especially if the cables are old/sticky. As an aside, I once had the throttle jam fully open due to carb icing just at the point where the well-lit dual carriageway ended and the twisty unlit snow-covered single carriageway began. And the magneto kill switch wouldn't work. Oh how I laughed.
The throttle slides do definitely bottom, with slack in the cables which are nearly new Venhill jobbies. I have one cable from the twistgrip going into a junction box. If anything, the throttle slide springs are too strong. I became very aware of all these variables when I was trying to get a decent tickover with the old carbs, and have again recently lubricated and checked everything. I wasn't able to get out there and investigate last night but I hope to tonight if she who must be obeyed doesn't scupper my plans again. I'll keep you posted as to how I get on. BTW Alan I'm in the sunny south too - well south east anyway, although with our glorious British summer I don't think it makes much difference where you are!
Martin,
When you say new carbs were they new or "used but good" your problem sounds to me like worn throttle slides/bodies but if they were new carbs and you have only covered 600 miles it is unlikely that wear in the carbs is the problem.
It does sound like too much air, you say you sprayed WD40 but without success, as you have a twin carb set up you may not have got to the offending leak, how about running the engine, let it speed up and drop off a plug lead and see what happens, you might be able to isolate it to one cylinder, you may want to plug the balance pipe to make sure that the cylinders are isolated, if that does not work try wrapping Denso tape (really greasy tape used by plummers) around all the carb to manifold and head joints basically wrap it around anywhere that you think air may leak into the carbs.
Two years ago I had the same problem as you on my single carb 99, I tried eveything but to no avail, in the end I fitted a brand new carb, since then I have had the sweetest running Domy, problem was a worn carb body.
Good Luck
Remind me, where?
The only reason I can think of for carbs changing themselves is sticky cables.
Sounds like your cable + splitter etc has shifted and is now pulling the slides. I'm sure there are other views on this but I lash the splitter to something stiff (probably the head restraint).
It's worth using a spanner to tighten the cable adjuster nuts on the carbs to stop them from vibrating away from optimum. But my money would be the cables.
Wow, still getting lots of good input here, this is great guys thanks.
Had her running last night, same thing. I'm using a remote fuel tank so I can get a good look to see whats going on. I am sure the throttle slides are on their stops and no cables are sticking. There is slack in all three with the twistgrip closed. I think I need to eliminate weak A/R springs first, as has been suggested- they're not broken, but how would you tell if they're not doing their job? I'm thinking replace them and see what happens, probably a good move anyway as I don't expect it has ever been done. Anthony, these were/are brand new carbs 600 miles ago, so I don't think it's wear either. For the cost, I think it's worth trying your tip with the plumbers tape and I'll try to pick some up today.
Thanks again gentlemen.
If you open and close the throttles, you should hear the clicks as the slides bottom. (Engine off, obviously.) If the slides stick before bottoming they don't click. The odd part of this development is that it happened relatively suddenly. Did you do disturb anything?
Yes, they click and no, I haven't disturbed anything - honestly! I'm very reluctant to mess with the carb settings until I need to - it took me so long to get them right, mainly because I usually only manage to get an hour or so here and there to work on it (pitfalls of having three teenagers etc). If I could get a good amount of time on it I'm sure it could be sorted, especially as between us it appears to be narrowed down to perhaps only two possible issues.It will probably be the weekend now before I can investigateproperly unfortunately, and I must admitthe draw toward a single carb is getting stronger because apart from this it's a cracking runner with no other issues.
BTW I'm on the Essex coast, a little ways down from Clacton on Sea. Don't want to be too specific, coz I'm not the only dodgy character round these parts!
Just wondered if you were in range for a ride out. You're a bit far for this time of year. I haven't been your way since the Weeley Festival in 1971!
I remember my dad taking me to that!
Justa quick update and a heads-up to all who have tried to steer me in the right direction with this. I thought I'd give the old girl a shine whilst I contemplated my next move, and lo and behold found that the left hand sparkplug was suspiciously loose - a little more than finger tight. Took both plugs out to compare, left hand one definitely burning leaner than the right. Back in and tightened properly, the revs were significantly reduced. Turned throttle stops back by about five degrees, and engine settled into a nice tickover. Also appears a bit more responsive on the road. I don't know if I should be embarrassed about this or not, as it's clearly my fault for not tightening them up properly in the first place. In my defence I will call it age-related absent-mindedness. Personally I've not heard of a loose plug causing this problem before, there were no discernibly odd combustion noises, so it hadn't even crossed my mind - apologies to all who assumed they were helping someone with intelligence!
Thanks again all.
Thanks again all. Dont be embarrassed about making a simle mistake just be glad its sorted,i could fill this site up with the mistakes i have made? and someone reading this post may remember it if they have the same symtons on their own bike and find the fault instantly regards nick
Yes Alan, as you said in the first place! I barely had to turn them though, it was pretty much there when I done up the plugs. I did say I was paranoid about changing the carb settings!
Thanks for your help mate.
