Advice on Dolls Head Gearbox just been rebuilt
Hi I have recently rebuilt my Norton Model 18 1936 Manx Dolls Head Gear Box. Bearings, Bushes, Seals, Push Rod, new clutch worm and nut. Having rebuilt this now when my bike ticks over the rear wheel does not drag and the revs go down real low at tick over now the gear box is not dragging which sounds glorious. I had terrible clutch drag before this work which made the bike after 10 minutes dangerous to ride, I was braking while the bike wanted to accelerate. I have now eliminated 90% of the drag on the clutch but there is still enough not to be able to place into neutral when I am stationary which is still a mystery to me with cable adjusted correctly. 3rd and 4th gear shift up and down on the go very nicely and 1st is ok but I have been pulling away in 2nd on the flat which the bike does not object to. 2nd is a real problem. I have to slightly release the clutch while changing into second and it then drops in with real thud and not a pleasant experience when it lurches forwards. I have a few ideas myself 1) I did not put the gear selector forks in the same place as I forgot so could it be a wear pattern problem ? 2) the dogs on my second gear did look quite worn but I wanted to get over this expensive rebuild before spending any more money on replacing gears. Would worn gars give this problem I assumed they would just drop out of gear. Any thoughts? Thank you Steve
Hi Ian
Re the dreaded norton clutch drag i would sugest checkiing the plates are flat
ihave a large surface plate and a sheet of emery cloth and give the steel plates a good rub this will show any high spots and get rid of any burrs ,the second gear issue may be adjustment of the rod between the two gear levers
Regards Roger
Hi Ian
Regards Roger
Thank you Roger. Yes plates are being replaced as soon as they arrive. I have sorted my gear problem out and learned a lot. I noticed yesterday my rear wheel slightly out of a-line. I had tensioned the rear chain by measuring the adjuster nuts equally but that did not put the rear wheel straight. Using the string method I was quite a bit out. On top of this problem the primary chain was very tight. I had correctly tensioned the primary chain, tightened the gear box bolts then adjusted the rear chain. This effected the primary chain and made it tight. All of this put together gave a shifting problem. Readjusted everything double checked and out for a short ride. No gear problem. What I have noticed is when I tighten the gear box up i can still effect the primary chain with my rear wheel adjustment. I donât know if this is normal. Also have the rear chain rubbing on my primary case so I am requiring a felt washer. The joy of removing the engine sprocket again ð?
You always need to finish primary chain adjustment by pushing it forward - ie start with it a bit tight then push forward with the adjuster. This takes up all the free play. Otherwise as you've discovered the bigger pull on the rear chain will pull the box backwards taking out the play in the wrong direction and making the primary too tight.
My rear chain runs very close to the inner primary cover at the back so have installed the split link with the spring towards the wheel rather than outwards just in case the extra width catches. A bit awkward to do it through the wheel spokes! I'm not sure how a felt washer would help?
At first, I disagreed, then remembered that the gearbox is pulled backwards by final drive tension, which is greater than primary due to gearbox multiplication of torque. So finish by pushing the gearbox forwards is correct.
In the years not running Brit bikes I had forgotten this. I must check if I have done it right on my own bike.....
I hear that modern bonded friction plates (especially the ones with Kevlar friction material) are more heat-resistant than the old-style ones with replaceable Ferodo inserts. But you can't do that to the chain wheel with inserts in them, as on the early clutches.
Another thing to check: is the gearbox properly clamped in the frame? The lower mounting hole on a Doll's Head box has a tendency to wear oval over time. If this has happened the bottom bolt will not effectively clamp the box between the lower frame rails, allowing the box to move even when you think the bolt has been correctly tightened. In turn this places stress on the upper mounting ears which can crack. The lower mounting hole can be bushed to restore the fit, ideally along with a new bolt. If doing this job check for gaps between frame rails and box and if necessary make a "top hat" bush for one side (or possibly both) to ensure a snug fit between rails and box so that an effective clamping action can be obtained.
Ian McD
I've done the same as Ian to give a bit of clearance 'tween chain and p/c case. Sounds not uncommon! Also re the primary chain tension, the view on this Forum seems to be to have it a bit slack (rather than a bit tight). From memory about 1" play but check that figure. My clutch is always better with a slack primary.
George
1" sounds a bit slack to me - mine is 3/4" (although always difficult to be precise). I agree too slack is better than too tight.
