There is a Mudguard of a 1964 88SS Domi available. Does it also fit my 1966 650SS?
Fritz
You're lucky, Fritz. I'd…
You're lucky, Fritz. I'd like the shallow guard for my 1963 88SS but the forks were widened for 1964. So I'm stuck with the deep guard.If it's a shallow and narrow guard then it'll fit mine and not yours!Unless of course the deep version is correct for 1963. Do you know, Anna?p.s. welcome back!
Previously David Cooper wr…
You're lucky, Fritz. I'd like the shallow guard for my 1963 88SS but the forks were widened for 1964. So I'm stuck with the deep guard. If it's a shallow and narrow guard then it'll fit mine and not yours! Unless of course the deep version is correct for 1963. Do you know, Anna? p.s. welcome back!
I have a 650SS late '66 and probably a '67 model it has what I would call a vallanced front guard as per the period photo's in Roy Bacons Norton Twin Restoration. Al
Previously alan_rogers wro…
So has mine.
Thank you all
Fritz
Hello the 1966 650SS had a shallow sports front mudguard and a deep valanced mudguard on the rear and so did the 1964 88ss and the two machine have the same wheel dimension , of 3.00x19 front and 3.50x19 rear , yours anna j
