Hello,
I would like ask you.
How many oil I need for my Domie to engine,gear box and front forks Roadholder.
Thank you
regards Lubos
In addition to the above y…
In addition to the above you may need around 130 to 140cc of SAE 30 for the primary chaincase. You can use a 10/W30 or 15W/40 or even a W20/50 for this as long as it does not contain friction modifiers which may make the clutch slip. The original oil for the primary chaincase and forks was called Castrolite but I have not seen it on sale for a while. Some people use a transmission fluid but if it leaks out can be unkind to any paintwork.
As an alternative for the gearbox, you could consider a 80W90 Hypoy oil or 85W90 or even straight 90. I like using a modern synthetic oil in my gearboxes. The oils seem to absorb less moisture and not need changing so frequently.
A good quality 20W50 oil can actually be used in the engine, gearbox and forks on a Norton if you have difficulty in getting supplies of the prefered choices.
Thank you very much guys !…
Thank you very much guys !!
Have a nice day.
Lubos
I think the last reply abo…
I think the last reply above lost (or maybe gained) something in translation, but I'm going to leave it there unedited. Lubos writes much better English than I could do Slovak and he has a quick and comprehensive reply. Exactly what these message boards should be about.
Webmaster
It's our pleasure, duckie…
It's our pleasure, duckie!
After Lubos' last comment…
After Lubos' last comment I'm pleased to say I use straight oil, SEA 40 in my Dommie engine and top up with SEA 30 in the Winter. Gearbox to the level with Castrol EP90. Primary drive to the level on the centre stand with SEA 20. Forks with either 15 or 20 weight fork oil BUT 200cc not the 150 it says in the book and that was the best thing I ever did to improve handling, apart from the modern Avon tyres. Warning: Do not exceed 200cc.
Please note: The only reason that engine oil was recommended over gear oil (EP90) in the gear box was because at that time Extreme pressure gear oil contained corrosive additives. Thisfor more than 40 yearsis no longerin the spec of higher quality gear oil, such as Castrol EP90 and is the specification for my Mk 3 Commando gearbox. An AMC box.
Previously phil_hannam wro…
Well Now there is no need for a for a SAE 30 in the primary chain case , now there is Harley Davidson primary chain oil that is formulated oil bath clutches , that will not let the clutch slip or eroded the clutch rubbers , you find this on ebay, its good stuff so try it out,
and as engine oil goes you need Morris golden film 20/50 and get 10% off with the Norton owners club . As gearbox goes do not use a gear oil with EP in it , you need Hypoly 80 castrol
EP stands for Extreme Pres…
EP stands for Extreme Pressure Anna, although the Harley Davidson primary chain oil sounds worth trying. Never had an issue with EP90 and I us Castrol EP 140 in my 16H Dolls Head box.
I accidentally put some semi synthetic light oilin my poor man's Manx primary 18 months ago and when the clutch started to slip I knew why. Got so bad that kicking it over was just like having the clutch leaver in...If all our fuel ends up with Ethanol contamination, most of this might not matter anyway.
Hi hi hi hi I am sorry for…
Hi hi hi hi
I am sorry for my english....
it was mistake...
dimensions Attachments g…
dimensions
Attachments g-jpgI wanted to order shim, an…
I wanted to order shim, and here id answer from RGM:
"Hello Lubos, I see now what is happening, rear isolastic shims are for the rear isolastics of A Commanado and will not fit A Featherbed. But it gets worse, your swinging arm is not as it left the factory it has been modified by a previous owner, the Featherbeds had metalastic bushes not bronze bushes. Unfortunately it follows that the shims you require are not a standard Norton item and could be any size, I am afraid you are going to have to measure them and go to a local hardware store. If you cannot get them locally if you quote the sizes and give me a little leeway ie bore 22mm upto a maximum of 23mm but down to 21 OK or something like that we have quite a lot of different shims both in the stores and in the workshops and may be able to find you something pretty close. Best regards, ..........."
What do you think about it ???
Previously neil_wyatt wrot…
Hello Neil I know what EP stands for we learnt all this way back in 1967, at Selby technical collage . and EP as some not nice additives in it that does not like bass or bronze bushes , its is why I said use Hypoly 90 Hypoly is short for High in polymers these polymers give a high bearing protection , aspeicaly with bass or bronze bushes , that there are in a Norton gear box, so using EP90 you may as well put sawdust in your gear box as its doing the gearbox no favors .your Anna J
Lubos: Please do not take…
Lubos:
Please do not take this wrong but I believe thet you should start a new, separate conversation about your swingarm. The members, when looking at the title of the current conversation about oil quantities, might just skip over it as theypresume that the question has been answered.
Best
yes , of course.. thank yo…
yes , of course..
thank you.
Hi Anna, I understand abou…
Hi Anna, I understand about the old EP gear oils and indeed, some of the cheaper gear oils still use the corrosive agents but not the good quality ones since some time in the 70's. This why it is recommended for my Mk3 Commando. No issues with that box. I use Castrol EP 90 on all my Norton gearboxes and Castrol EP 140 in my 16H Dolls head box as it's thicker. No issues to date and no sawdust!
yes Neil it dose say if you read it not to use anything with EP in it as it attacks yellowHi Anna, I understand about the old EP gear oils and indeed, some of the cheaper gear oils still use the corrosive agents but not the good quality ones since some time in the 70's. This why it is recommended for my Mk3 Commando. No issues with that box. I use Castrol EP 90 on all my Norton gearboxes and Castrol EP 140 in my 16H Dolls head box as it's thicker. No issues to date and no sawdust!
metal like bronze or brass bushes say i have been saying all along . !! yours Anna J
yes its Lucas oil made for oil bath chain cases ie Norton or Harley Davidson , Triumph / BSA !!! yours Anna J
Hi Lubo, you must be think…
Hi Lubo, you must be thinking that 'ground hog' day has arrived as you keep reading reprints of reprints of reprints of the same text.
Can I apologize on behalf of all the NOC members who are trying to givea few sensible answers to your questions. You must be wishing, at times, that you had not bothered in the first place. Mike's suggestion of starting a new thread about your swinging arm is very sensible but the chances are that you may still have to read through loads of mostly pointlesrubbishor repeated text to learn anything new.
Your swinging arm appears to had been modified to take bronze bushes.This was a very common conversion in the 1960s to help improve the Featherbed high speed handling. In the UK, companies like Dresda Auto and Unity Equipe were the specialists to talk to. They are still around and may be able to help you.
hi Phil Thank you very muc…
hi Phil
Thank you very much
thats OK... J
There are many things which I would like to say, but my big problem is the English language. I dont speak very well English ,so I have no choice but just read what I find here.
(help with Google Translate)
I am grateful for any advice and help,but Iam not sure if people understand what Iam writing
Iam happy that there is something like this forum NOC.
Great !
The manual states that the engine oil tank has a working capacity of 4 1/2 pints (2.3 litres). It recommends S.A.E. 20/50 or S.A.E. 30, but may vary, depending on where in the World you are. The gearbox has a level plug at the back, which will tell you when to stop filling it with S.A.E. 50; and each fork leg holds 142cc (5 fluid ounces) S.A.E. 20 grade oil.
Ian
