ES2 Big end madness...
Quite happily replacing my big end on my es2. But. How the hell do you hold the bottom row of rollers whilst you spin the rod over the top row? I've tried grease, wire and even a cable tie to hold them on....I'm going doolally trying! All the best.
string
Fishing line. not tied ,so you can pull out after assembly. Learnt as a boy re-building cycle gear block freewheels and also usefull when reassembling PSR8 switches.
Brilliant and thanks! I tried copper wire and it didn't hold well enough - fishing line. Now that's an idea! Thanks again I'm off down the shed...
