Hi all, I am trying to determine the correct part number for the condenser in my 1963 Model 50. I know the points are "425219'. Can anybody confirm for me the correct condenser is "54410823" ? Pic attached below.... Thanks in advance. Clive.
As these condensors are ei…
... or even remotely, hidd…
... or even remotely, hidden behind a panel. In theory it should be close to the points but in practice it makes no perceptible difference.
My current condenser works…
My current condenser works fine. Merely looking to have a spare on hand. Really appreciate if anybody could confirm the correct part number for me?
It does that. If you fit a…
It does that. If you fit an ignition booster ,Boyer/pazon you can do without the capacitor and the points last forever and starting/running much improved.
hello, is this the one. h…
http://www.rexs-speedshop.com/epages/es143131.sf/en_GB/?ObjectPath=/Shops/es143131/Products/CND-16
Barry
Thank you gentlemen... app…
Thank you gentlemen... appreciate the confirmation. Clive.
As these condensors are either very old stock or probably pattern made god knows where I would fit a std car one on the outside of the dissy.
