Find the numbers on a Featherbed?
Hello,
Where is the numbers on a frame Featherbed ?
Thank you,regards,Francis (french member)
They're on the flat piece of the frame on the rear loop on the kickstart side. Just above the rear wheel of the dolly in the photo. I had to scrape the paint off mine to find them.
featherbed-frame-jpg
Is it possible that the location of the frame numbers depends on the year/type/model of your bike.
The frame number on my Slimline1961 Model 50 is on the left side frame stiffener just above the rear brake pedal pivot.
My 1956 Wideline is also on the left-hand side, on the plate above the swinging arm pivot. The numbers run vertically.
Judging by Bruce's photograph, which is of the left-hand side, I think he meant that side too!
Yes I did mean that, sorry for the confusion, it's not the kickstart side! I hope you found it Francis!
Hi I'm contemplating the purchase of a racing Norton model 99, but there is no number legible on the plate above the left swinging arm pivot. The engine number confirms its a 1958 model but I am a bit concerned by the lack of a frame number (see attachment). Are there any other markings on the frame that can identify it e.g on the headstock or elsewhere? The bike has no paperwork. Would appreciate any help on this matter.
frame-number-jpg
Sadly, a good number of racing bikes were once someone else's pride and joy. Of late there has been more of a crackdown on stolen bikes appearing on the race circuit but obliterated frame and engine numbers are an indication that this bike may havea dodgy past. Acid etching could reveal the number - and someone might well be relieved to find that their long lost machine has been found.
Hmm, could open a whole can of worms! The engine, being 1958, may, or may not, be in its original frame. If not, when, and why was the frame changed? Back in 1957, a van pulled out of a side street in front of me, (fortunately I was only doing 30 mph). The resulting impact bent the front wheel, and the frame below the headstock. Norton supplied a new frame. When the bike returned, after repair, it had the original matching numbers. Either the frame was supplied with the original number, or it came unnumbered and was stamped by the repairer. If frames were supplied unnumbered, how many bikes were rebuilt without being stamped?
Gordon yes your right on the money here lots of bike stolen end up as parts
and sold on as parts only to leave the frame , number are gound back or holes drilled thorugh the numbers so you cannot see them right or make them out,
its was some poor man's pride and joy to end up as parts gone to 4 corners of the globe, so been very careful of what your buying in our days , ask lots of question . you can sometimes smell a rat, and walk away and find sometime else if you feel its not right, the acid testing or xrays can come up with a frame number, but most are drill out, and welded over, then you know something not right with it all ,
so buyer bewear
yours anna j
If you want to road register it, you won't be able to, and if you want to race it, you could find the Police feeling your collar, if you present it for scrutineering without a number. Basically, you can't do anything with it.
Walk away, and maybe report it yourself. If the seller has nothing to hide, he has nothing to fear.
Thank you allfor the comments.I think I will give this one a miss. Sounds like more trouble than it is worth.
very wise man . you save your self a lot of trouble , Yours anna J
Just one last thought on the matter. Does the NOC keep records of frame and engine Nos? If so would it be possible to check the status of the engine number & correspondingly the original frame number? If so what is the procedure?
Daniel,
All posst war Nortons had matching engine and frame numbers.
regards
Daniel. Do you mean find out what the number should be, and stamp the frame accordingly? You could end up with a criminal record for that! There is nothing to say that was the original frame, which may now be road-registered, and in someone else's ownership. Try registering it and see what happens..... there will be a loud knocking on your door.........surprise
Ian, That wasn't my intention but point taken. Thanks for the comment.
Obviously the the original frame and engine numbers were the same. If the bike has a current registration, check the frame number. Providing the numbers still match, simply restamp the frame with its original number. No one will come knocking on your door, as this number will be on the DVLC computer already.
You have missed the point. As Daniel stated in his original post, there is no paperwork, so unfortunately, that course of action falls down at the first hurdle!
Look at the headstock and at the frame where the head steady attaches.On my Norton the number is repeated in small lettering ,hard to spot.
Er, missed the point, which one? The original post was by Francis, not Daniel. As usual, like a "Chinese Whisper", replies no longer relate to the original. The fact that a frame has no visible number does not necessarily mean the bike is stolen, or illegal. Buying ANY vehicle without paperwork is always a big risk.
Thanks for that Robert. That was in fact my original question.
Hi Daniel, my featherbed frame numbers took some finding in that location under layers of paint. i thought i had rubbed down to bare metal but still saw nothing so got some thinners on a rag and gave it a rub the numbers slowly appeared but they were very faint. but there never the less. Baz
Thanks for the tip Barry
This may or may not be relevant to your case, but the frame number on my Slimline became invisible after I had the frame powder coated. You can just about make it out with a bright light at a certain angle if you know where to look.
John. If you wish to be pedantic, I did state 'Daniel's original post'. I was not referring to Francis' original post. There are two threads going on in here, which may cause slight confusion. However, your reference to 'restamp the frame with it's original number' clearly refers to Daniel's situation, not that of Francis, as it is Daniel's bike which has had, apparently, it's number removed, as witnessed by his photograph. I therefore stand by what I said. Unless he can find the number by the headstock; and I certainly cannot spot one there on mine; then it would be inadvisable to simply stamp the engine number onto the frame, expedient though it might seem.
It could bite you back, Daniel!
well to do any formal stamping you have to go too Dave Catton to verfiy the number a the ones that was on the frame from the factory, then I have all the origianal Stamp puches too stamp mark frame but this would have to be done with dave catton over looking this so it then goes into the record and the DVLA as well as they would need to know the frame as been stamp marked recovered , by the Norton owners club so then it can be registered with a year related registation number
so a lot of hurdels to jump overm yours anna j
