I am in the process of rebuilding an early 650SS engine and would appreciate some advice on how much metal I can lose from the rocker gear in order to gain a bit more ooomph.
As can be seen from the attached pics, I have trimmed two duff camshaft followers in different ways for some practice. The left follower has been ground away, in the suggested Dunstall manner, but not quite to the extremes seen in his Tuning Book. This took nearly 25 minutes to achieve and would probably have led to complaints from the neighbours if I had done another three. The right hand follower lost weight, quite simply, when a 3mm pilot drill followed by a 12mm monster chewed through the sidewalls. This tookjust5 minutes and I could probably have done the whole set before noise reps from the Council arrived.
The facts.......each virgin follower weighed 73g dry. The milled job then hit the scales at 62g whereas the drilled item was 66g. I was a little disappointed at the meagre results but in percentage terms we are talking 18.5% & 13%. Now before the number sharks jump on my rough calculations, I am factoring in the 3g of oil that sits in the bottom of each standard follower when the engine is running. So the dry 73g now rises to 76g wet. In my lightened rockers this will mostly drain out of the enlarged cutaway sections. But, as you can see in the other pic, I have cunningly drilled the corners to provide drain holes to drip on the camshaft lobes.
I am going for the Tesco solution with all the bits. So rocker arms and valve bits are next on the hit list. But am I making the right kind of moves and will it make any difference? What about those follower corner holes? Will they be more of a problem than a solution?
cam-followers-jpg
An interesting project Phi…
Hi Ian.....attached photo…
Hi Ian.....attached photo shows my collection of lighter chunks. The saving in weight with the rockers was big whereas the purchase of the all alloy pushrods was an expensive mistake. Table below shows differences between original and mistreated parts,
original lightened
rocker 133g 100g (inlet)
follower 73g 66g (original oil-wet follower 76g)
valve cap 17g 9g
pushrod 32g 35g (both as purchased)
I appreciate that Titanium and Carbon Fibre have arrived as modern alternatives butI am trying to make this a DIY challenge as far as possible to save cash. The Norvil website offers lightened rockers at £174 a set. Probably for a set exchange, with P&P and VAT to add on and shake your wallet. Though I must admit that I found grinding down my rockers a noisey, time consuming and very messy task.
The Wassell pushrod, being heavier, was a huge surprise and from previous experience, they are easy to damage.
My reasoning, regarding the drillings at the rocker base, was that oil would just dribble down the corner angle and hang on to the Stelite foot until the camshaft lobe arrived.
lightened-valve-gear-jpg
Phil. I agree about the pu…
Phil. I agree about the pushrods. The attached picture shows what appear to be the same, as found inside my engine when I stripped it in 2009; chunks out, bits broken off; not what you want to find in your p&j. Definitely best avoided.
I have done some weighing, and to my shock, the hollow steel pushrods I have bought from RGM weigh 69.3g inlet, 66g exhaust; nearly 2 1/2 times the weight of standard ones! They are going back....
Dural adjuster nuts 1g; standard 3g. Quite a saving, for £6 set.
Standard tappet adjuster 6.2g. RGM hollow allen key version 5g; mushroom head version 5.6g; 20% and 10% saving respectively. Expensive at £36 and £50.40 a set respectively. You could grid a bit off the adjuster square head, and run a drill part through the standard ones, I guess, provided the faces are ok.
How did you manage to shave all that weight off the standard valve spring caps? Titanium ones weigh 10g each, 1g more than your lightened ones! £58.58 a set, too....
My rockers are lightened, inlet being 103g, a little more than yours. It seems that much of the saving is around each end of the arms. I see that you have tapered the outer main body, whereas mine are still parallel, hence the difference. Did you use a bench grinder, or an angle grinder intially? I want to do the sameon my Commando ones.
All the above prices are current, from RGM, including VAT. Since I bought these items in 2009, the prices have rocketed by 50% (adjusters), 63% ( valve spring caps), and 100% (dural adjuster nuts). That's some inflation....
Ian....you have given me a…
Ian....you have given me a few ideas I could try out..... such as drilling my adjuster nuts through the sides. It would be interesting to see how much weight is saved with three 2mm holes.
The valve caps could be Titanium but they look more like Duralium. I could probably haved drilled these as well but they are now inside the head.
The pushrod weight discrepancy applies to many versions. I have an orignal Model 7 steel rod which is only 1g heavier than the later Model 88 alloy with steel ends type. I also have an 88SS inlet that weighs in at a mega 53g. Must be an RGM special!! The lesson I am learning fast is to check each component's weight to ensure that sets are all equally matched.
My rockers were all ground down using a variety of shaped, course stones and the odd cutter. The finish was achieved with finer stones, rotary fibre discs, files and emery cloth strips. It took absolutely ages to get them all similar in weights. I made loads of mistakes and there are dings all over each rocker. The residue, from the grinding, got everywhere around my workshop and this is definitely one, never to be repeated, piece of bodging.
Phil. Yes, the spring caps…
Phil.
Yes, the spring caps look like dural. I thought you meant they were original steel ones which you had lightened; you had me going there! The dural ones are thicker, and a bit lighter than the titanium ones.
You could try drilling the nuts, but a set of dural ones is only £6, and you could never save that much weight by drilling the standard ones. I reckon you could save a bit on the adjusters, though. Every little helps....!
By the sound of it, I am lucky that my 650SS rockers have already been lightened. I really want the same done on my Commando Proddie Racer ones, but maybe not by me! There is so much weight to save there...
Ian....have just been tink…
Ian....have just been tinkering in the workshop with a spare adjuster screw and its nut.They both easily took a 2mm drilling so I then got brave and tried a 3mm bit. This was a too ambitious for the nut and one exit point was very close to the face surface. A 2.5mm drill and more care might be a better move.The adjuster was ok, probably because it is thicker to start with.
My scales now show 2g for the nut and 5g for the adjuster. I am going to look again at the cam follower and see if a 13mm drill and mill will get it lighter by a few more grams (grammes).
be careful with dural valv…
be careful with dural valve spring caps they vary in quality and the collets can either pull through or lock thereselves into the dural cap ,,,,,,,,,,,best of luck with it Nick
All sounds jolly exciting.…
All sounds jolly exciting. Two tiny caveats though. A good friend of mine used to race prepare Velocettes. I watched him do a wonderful job lightening a pair of rockers - a work of art. However they both snapped mid race. Don't take metal off the wrong bits. The other one is that inertia in the valve train leads to valve float at high revs. Lighten the valve train and valve float occurs later. In my case with a lovingly prepared 99 engine, a conrod broke before valve float set in. Had I not lightened the valve train, just possibly valve float would have stopped the engine reaching catastrophic rpm. The flailing rod cut the engine in half. Quite impressive. 650 rods should take the stress rather better than 88/99 ones though. Always best to ensure the inlet valves float before the exhaust valves - nature's rev limiter.
One of my memories from th…
One of my memories from the 60s was the number of owners who purchased a new 650 only to have the bottom end disintegrate within 12 months. Often caused by too much right-hand twist for too long.
Those were the days when a night out often meant finding someone with a Triumph Bonnie to race against. Generally there were no rules, just natural limiting factors. ie. The T120 (or similar) would usually have the edge on acceleration but not get round the first bend. Also, as these were the days before full-face helmets, insect face strikes at around a ton could be exceedingly painful and very distracting.
Nick is quite right about these alloy valve caps. I have had one jam on a valve stem already. So I heated all the bits up to try and expand the cntre-hole and release the collets and bang!!! A spring wizzing past my ears and a collection of bits.
Phil. I think that 5g for…
Phil. I think that 5g for the adjuster is a good result, and would stick with that, to avoid weakening. Likewise with the nut, which needs to be tightened hard. You wouldn't want one to fail, as in break asunder, whilst the engine is running. I have actually had a nut come undone, which thankfully nestled in a corner of the rocker box, doing no harm. I was alerted by the increased tappet noise! If one broke up, I wouldn't be so sure of the same result.
Nick. Yes, even RGM, who supply both dural and titanium caps, recommend the titanium for their extra strength, despite being a nat's heavier. I have titanium ones ready to go in my Commando.
Gordon. I imagine that slimming the arms down just behind the adjuster would create a weak point. There is lots of metal around the adjuster and ball-end, which could usefully be removed, whilst leaving plenty of meat on the arm itself. Tapering the main shaft casting could no doubt be safely done, as Phil has. One imagines these were over-engineered originally for reliability, but as you say, proceed with caution.
With regard to your 99, maybe it was your right hand whch caused the failure, not the lightened rockers! I have Commando rods in my 650, which are stronger again. Gear ratios come into play here, in that, with the correct ratios one should not need to max out the revs in the intermediate gears in order to drop it into the power band when changing up. The standard ratios leave something to desire here. A 5-speed semi-close ratio box sounds like a good idea, but mucho dinero, unfortunately. Closing up 3rd & 4th would help. Rambling thoughts....
I fitted lightened rocker…
I fitted lightened rocker adjusters to my Commando more than 10 years ago, with the alien head. Made the adjustment a piece of cake and more accurate and never needed to adjust these tappets since!
In fact it was only reading this that reminded me I fitted them, bought from RGM. I must remember to put them on the 99 and 650 when that motor comes apart after Christmas to reveal goodness knows what!
More about that later.
The objective must be to r…
The objective must be to reduce the moment of inertia around the rocker shaft. So bits furthest from the shaft contribute most because the square of the radius so so much bigger.So there cannot be much (if any) point in removing metal from the shaft boss since its radius is so small. The bits of casting out beyond the adjuster are maybe 10 times further away so it's 100 times better to remove metal there.My bike is fragile enough without taking away more strength.But Dresda uses valves with much thinner stems and lighter springs. More to be gained there, maybe?
Fair point David. I imagin…
Fair point David. I imagine that is why who ever lightened mine did not lighten the shaft boss; see attached photo of my lightened 650ss rocker alongside a standard Commando item. The areas most lightened are, as you say, at the far ends of the rocker arms. The remainder just appear to be polished. I am not even sure of the benefit of polishing them, unless someone can enlighten me as to the advantages?
rockers-lightened-standard-jpg
Polishing should eliminate…
Polishing should eliminate any obvious imperfections which act as stress concentrators. It doesn't take much of an imperfection - a scratch will do - to act as a focus for crack propogation. Of course, once polished it looks rather smart so that's reason enough.
When I first started to sh…
When I first started to shave metal off my rockers they looked very similar to Ian's. Just thinner at each arm end. But I quickly found out that thinning down and polishing the shoulders was relatively quick and easy compared to around the arms. Therefore even less weight to be pushed about.
To add to Gordons comment......polishing also allows any oil to run off the surfaces more quickly thereby helping to keep inertial weight low. Surfers wax and polish the tops of their boards ,similarly, to help get water to run off faster..
Of interest to other budding metal grinding mates......I found that after grinding and polishing this current set of rockers, they had all distorted slightly to the point of binding on the respective spindles. I can only assume that removing metal was allowing the stress paths to change and hence distorting each rocker a little. I used some T-Cut and elbow grease to sort this out but wondered if perhaps an hour in the oven at high temp might have helped as well. Apparently you get similar distortion issues with cylinder heads that have survived major surgery.
Why would you want to ligh…
Why would you want to lighten the valve gear in the first place?
There is two reasons for l…
There is two reasons for lightening the valve train. First the lower inertia reduces wear, especially on the camshaft. Second it allows higher rpm before the springs force can't close the valves fast enough. As said before polishing is always a good thing to do.
Another reason is that we always has regarded British motorcycles as raw material, which with love and care can be improved to something much more goodlooking and efficient.
Fair point Bob. If you are…
Fair point Bob. If you are going to ride your bike remotely sensibly - i.e. keeping generally below 5,000 rpm, there is no need. Camshaft and cam follower wear are minimal in normal use. However, if you are heading into the realms of 6,000+ rpm it does make sense as valve train loads become severe. What a lightened valve train can do is permit the use of softer valve springs for a given max rpm. No bad thing. Valve train flexure at high rpm is quite fascinating. My uncle used a strobe light to view the exposed valve gear on his Rudge. As rpm increased, the pushrods flexed to a remarkable degree. Quite amazing, and yet Rudge pushrods have a reputation for reliability.
Previously bob_johnson wro…
Well Bob, you might as well ask "why ride a Norton?", when modern bikes are faster, and handle as well, or better. We all have different reasons, in my case nostalgia for lost youth. Few would go to Phil's extremes, to extract the ultimate performance, but, you must admire his dedication.
In the late 50's, I built an Austin 7 special. Top speed was over 90 m.p.h. ( not bad for a 750cc side valve), was it worth the effort? To me "Yes!", but not many would agree. Polished com-rods, gas flowed ports, lightened flywheel, been there, done that!
Surfers wax their surfboar…
Surfers wax their surfboards to get a layer of sand to stick to the wax so that their feet don't slide around.
Back to the thread, about 2 months ago a well known Norton racer in the States posted a picture of his blown up engine on the Access Norton website. His Maney crankcase, Carillo rods, Maney alloy barrels and one piece crank were all trashed. Whilst I didn't comment, I thought, "thank goodness no genuine Norton parts were damaged"
Also, When changing push r…
Also, When changing push rods for ones made of a different material, How will they expand compared with the original and how will that affect your valve clearances?
Previously david_evans wro…
Good point David. There are probably not many twins running with the old steel pushrods (as fitted to iron head engines). A previous owner had put alloy rods in my '54 Dominator, this caused endless problems, until Phil put me right. I was going in circles, changing timing, carb settings, cleaning the mag, ext. All was due to the extra expansion of the alloy. Increasing valve clearances was an instant cure.
This change of material fo…
This change of material for the pushrods is an interesting point as you can now get them in a range of very exotic substances. I thought about making some out of carbon fibre. My local model shop sells this, in tube or woven mat form, for the model aeroplane lads to strengthen their wings. It is easy to cut and shape so my plan was to superglue the steel ends onto some carbon rods in place of the alloy tubing. The drawback was the thickness of the carbon tubing walls which made each one as heavy as the alloy it was supposed to replace. perhaps somebody sells these with thinner walls.
Panic Time................…
Panic Time.................... I had nearly reached the point of assembling all the big chunks when I discovered that one of my cam follower locking plates had decided to split. See attachment. This I have never ever come across before. Fortunately, I had a spare set from an older set of barrels.
So my lightened camshaft followers are now in place in the rebored barrels. The pistons have been fitted with gapped rings and are also sitting inside the barrels. In the past, I used to gap the rings using a file and then a steel rule wrapped in fine wet & dry. Now I just get the out my Dremel lookalike and use a fine diamond coated wheel to grind off the excess.
The intermediate timing pinion has been on a diet. But two afternoons of drilling only saw a meagre 10g shaved off its 375g bulk. The holes are 6mm in diameter. I really wanted to go up to 13mm but the screeching of the drill was too much for me let alone the neighbours. On the opposite sprocket face, I can drill six 5mm holes through both both and save another 10g. Is it worth the time and effort?
cam-follower-locking-plates-jpg
Near Disaster......after 3…
Near Disaster......after 350 miles of riding, to bed in the pistons, one of the exhaust rockers broke leaving me with a 2 mile push home. Fortunately, I had another spare lightened exhaust rocker ready to fit. Two hours later I had the engine running again without having to remove the cylinder head. Amazing!!! This was achieved by pulling out the rocker spindle and then removing the broken rocker through the front cover port. As can be seen in the photo, it was a clean snap and no spare bits appear to have disappeared down the pushrod tunnel.
Rode the bike to Popham Bike Rally today.....80 miles round trip. No problems. Great show, as usual. Of interest....for sale in the auto-jumble was a complete, ready to fit and go 961 engine. Just £5000 to the lucky new owner.
www.nortonown
After reading this I am do…
After reading this I am doubly determined to to keep my Atlas in a gray porridge rough casting state of tune.
Ah yes, this isn't the fi…
Ah yes, this isn't the first exquisitely lightened and polished rocker I have seen that has snapped. The older I get, the more I am inclined to Jonathan's school of thought.
A thought: Is it better to have a low-tuned engine you can thrash with confidence or a highly-tuned one you are frightened of braking?
An interesting project Phil. I will be keeping my beady eye on your progress!
I think that the oil which drips from your drain holes in the corners will miss the lobes, though, as the latter only bear on the centre of the followers. However, any oil in that area is good!
Of course lightweight valve train components are available; titanium and dural valve spring top collars, titanium and alloy pushrods, lightweight hollow tappet adjusters, titanium locknuts etc, but I am not sure what can be done to lighten any original items. More a case of throwing money at it really.
The rocker arms can be lightened, but quite how, and by how much, I don't know. RGM used to do it, for around £90'ish a set, lightened, balanced and polished, but don't anymore. They recommend not taking off too much metal. The rockers in my 650SS had been polished before I got it, but whether they are lightened as well I don't know. My top-end is stripped at the moment, awaiting new rocker spindles, so if you would like to weigh an inlet and an exhaust rocker, I will do the same. If mine are lighter, I can post up pictures, and if you do likewise, we may be able to identify from where the metal has been removed.
That's a start!
