Hello, first time forum poster, long time stalker. Probably met quite a few of you at the rallys.
On to the serious stuff, bought a 650ss in bits. kinda threw it together. It rode OK, but needed to come apart again so istripped it back down after a rally and made a list of stuff that i thought was all sorts wrong.
Mainly the speed of the thing was all off, got onto a nice stretch of road and opened it up. i got 80ish mph, in top gear, at red line (WHAT!? the book said 115!).
Another problem with the bike was that i lost feeling in my right side after 10 mins, the left side took only another 5 mins. It shakes like crazy!
ive attached a photo of my sprockets n' clutch. engine sprocket is 21T, clutch 42T, Gearbox 19T and rear is 42T.
Im going through the whole thing changing & lightening all sorts, from drums to disc brakes. 4 speed gear box (why? why was this a thing!?) to 5 speed. and suspension ("road holder forks"!? you mean "bottom out Stalks"!!).
Can anyone suggest whats going on? any help would be greatly appreciated. Thanks in advance!
img_20160110_122442111-jpg
The gearing you quote is g…
Pretty sure the speedo and…
Pretty sure the speedo and rev are good, they are original...i think.so that points to the clutch, but i do remember it being gorilla strength. however im used to modern jap stuff...so maybe it wasnt that tight.
I had planned on getting a belt drive, now i have more reason to do so!
Atlas pistons you say? all super light and everything you say? hmmm, im convinced! where would i acquire such light weight pistons? I had planned on also getting some CNC ally conrods too.
Also, in regards to the forks, i plan to put progressive springs in and whop the old bronze bush back in below the new one, and also stick some external springs on it and put in heavier oil. do you think this will give me adequate damping or am i braking up the wrong tree?
cheers Phill for the advice, about the sprockety setup and ballance.
No need for CNC rods as be…
No need for CNC rods as better forged rods still availiable. Hemmings can advise on forks. If existing pistons in good order get them lightened and the crank balanced. 80 mph is only a cruise for any good SS ,the std 88/99 clutch is good for a ton .
I don't see that design c…
I don't see that design changes will help. Better by far to try to get it close to original. A 5 speed bix wont make it faster. Just £1000+ more expensive.Is the camshaft giving the proper lift? Is the valve timing correct? If it is vibrating is the head steady tight? Do the carbs have the right jets? I'd get the basics correct before making costly 'improvements' to a sound design.Best wishes... David
Some good points here Dave…
Some good points here Dave. Out of balance carbs will cause bad vibes and rob the bike of power. Are the carbs correct for the engine? I put two big concentrics on my 650 bike and it actually went slower!!!
I only found a 5 speed gearbox useful on a track day run. An AMC 2 gearbox is fine for the normal power range of the 650 engine.
Carbs are on the list to b…
Carbs are on the list to be looked at and replaced as I'm going to port the head. But that would more than explain the two main issues with the bike. I shall inspect them tomorrow.
The bike was a box of bits, not enough for putting back as original. The plan is to make a Dommy racer for road use. The cam shaft I'm not sure about but I will measure it up tomorrow. I have got a PW3 to replace it.
Cheers for the advice guys! I'll post what I find tomorrow
Previously Tom Mudge wrote…
Hello Tom, it does sound as though the clutch is slipping, but don't believe all the speed claims made for the 650ss - I had a brand new machine 1967, which was well run in and would manage just over 100mph(indicated ) in 3rd but on the straight would never go any faster in top! It also threw oil out of the engine breather after driving for about 30/40 miles, didn't burn any oil though and when returned to the dealers was taken by the late John Hudson who altered the return pipe in the oil tank, checked the engine settings and track tested it at Elvington, and confirmed that it was correctly set up and would only hint at the fact that the speedometer was very accurate-hence a disappointed buyer as I went proddie racing with it - eventually getting somewhere near the claimed output after spending a lot of money(oversized carbs, inlet sleeves removed, curley cams, h/c pistons special v/springs, etc)
Regarding the vibration, did you check the primary chain tension afterwards, I had a similar happening at a track day with my current 650ss,the bike slowed and vibrated badly, I was thinking all sorts but the gearbox had moved under braking and downwards gear changes and pulled the primary chain tight.
As for it shaking, that's a headache, could be tyres/tyre pressures, rear/front suspension, head bearings, sw/arm bushes, wheel alignment - AAARGH!!
good luck with it, hope that its nothing major!!
Regards Terry
Hi Terry, After 1963 you d…
Hi Terry, After 1963 you did not buy a new Norton. It was a lash up by AMC . I'm not surprised you were dissapointed. Even in the good old Bracebridge St days the bikes were not totally consistent .If you got a good one they were brilliant but everything had to come together just so.
Cheers for the advice terr…
Cheers for the advice terry
From what I remember the clutch never felt like it was slipping, and it pulled strong... I also remember it still having lots more "go" in it at 80mph, it was just the rpm stopping me. When I took it apart I remember the tension being fine on the primary chain.
what was mentioned before about carbs got me thinking, if I'm sitting happily shaking my eyes out at 8000rpm and I'm in top gear, what's going on with the carbs is relatively negligible. As the carbs are supplying the engine with enough go juice to keep it at 8000rpm. Alright, maybe I had compression leakage or maybe some clutch slippage and slightly off mix of fuel. But not 20mph and a few thousand rpm difference...right? I think the problem is gearbox related. I'm gonna take it apart at the end of the month.
On a side note, I don't suppose anyone's got or knows someone with a commando disc hub and matching fork sliders for sale, I'm in the market for some, but I'm not exactly overjoyed at the price of all that from RGM.
I've got the answer......…
I've got the answer.........its not the clutch slipping. Its the Rev counter drive box. These came with a choice of 1:1. 2:1 or 4:1 ratios. It is quite obvious that you've got the wrong one and your engine was only actually peaking at 4000rpm. You need to open the throttle a bit more.
Looking back at some of my old Magazine road tests. I note that the 750 Commando, with a 19 tooth gearbox sprocket was only good for 105mph two way average. This rose to 115 when the g/box sprocket was changed toa 21 tooth item.
The Motorcycle, in a 1962, got their 650 to a two way average of 111 mph. They quote a final gear ratio of 4.53:1 which suggests an AMC2 gearbox using 21T engine, 19T gearbox & 43T rear sprockets. Assuming little tyre and clutch slippage this equates to an engine speed of around 6500 rpm. To achieve 120 mph, on this gearing, would require over 7000rpm.
This is useful gearing cha…
This is useful gearing chart, just add your own ratios and sprocket sizes and bobs your uncle!
http://www.gearingcommander.com/
dan
Hi Tom, Totally agree with…
Hi Tom,
Totally agree withPhil,on your gearing 100mph should be around 5750 revs. At 8000 rpm I think your engine would have been strewn along the hard shoulder. Unless your miss a gear, it's unlikely you will over-rev the engine in top so give it what you can with the right conditions and see how it is then. Regards, Richard.
Terry makes a very good po…
Terry makes a very good point. 115mph may have been possible with a factory prepared road test bike but pretty unlikely from one off the showroom floor - despite what some people claim.
Before going wild with major expenditure, some time spent on the simple things may well make a substantial difference. Ignition timing and carb tuning being the first items, though if you are a student of that excellent tome Tuning for Speed, tyres, chassis and brakes arewhere you start. Then transmission and finally engine. For vibration, the head steady is the most obvious culprit. When mine was loose, the vibration shook the plates off the battery.
Hmm, I went and had a look…
Hmm, I went and had a look at my rev counter and found out that 8k rpm would not have been what I was hitting, it would have been something lower. From memory I thought it red lined at 8k however it seems it's more like late 6ish. Everything you've said Phill makes sense and some great info on gearing and such. And also thanks Dan for the Web link, that will come in handy.
Now here's the but. I blew the head gasket when I was testing this top speed out. (this was over a year ago now) and that's what prompted the strip down. So I'm pretty sure the rev counter was somewhat true...maybe?
after throwing it together just over a year ago I only got 500miles out of it and thought "hey this speed and rpm seem off, I'm gonna give it a blat on this open road an...oh nuts the head gaskets gone". The more I'm thinking about the speed issues the more I want to take that gearbox apart, I'm pretty certain on a 5 speed so I think I'm gonna have to take a look at it this weekend.
I agree Gordon, however expenditure is not too much of an issue, nor can I avoid it too much. It was a box of bits for roughly 30years, so all the chrome and paint are destroyed.The other day I stripped the rear hub out and have been polishing it up for alloy wheels. I'll have to get new carbs as I will be porting the head. Converting the drums to discs. New rear suspension. Alloy petrol/oil tank. Belt drive. The list goes on, sorry if it annoys the purists, but the bike was a box of bits.
Purist, me? Nah, anything…
Purist, me? Nah, anything that makes a bike more usable has got to be a good thing. Looking forward to seeing how this one turns out.
The gearing you quote is good enough for over 110 mph. So either the speedo and/or the rev counter are dodgy or the clutch is slipping. Probably all of these!!!
My own 650 is a jack hammer special above 70 mph, whereas my previous Atlas 750 was turbine smooth.
The difference........the Atlas had super-light pistons matched with a balanced crankshaft. The 650 had the opposite because I was trying to beat a build deadline and did not stick to my original plan.
To stop the 650 clutch from slipping I had to wind the adjuster nut nearly fully home. You then need a Gorilla sized hand to operate the lever. Plus the cable keeps breaking. A belt-drive conversion is one cure for these problems.
