Hi All
Does anyone have any tips for removing carbon deposits from cylinder head and ports? I've been using wire wool , brake cleaner and elbow grease which works quite well but I am struggling to clean around valve guides before I remove the.
Best Regards
Simon
Acetone also works well.
A local Vapour/Vapor/Aqua…
A local Vapour/Vapor/Aqua blasting man was doing special deals in my area, in order to raise his profile. I got a Commando head done for just £10. In this part of the UK that's equivalent to 2 pints and no change so it was easily worth it.
1 Pint costs GBP5.00??? At…
At that rate I will bot be able to stay very long on my next trip over.
A small wire brush on a dremmel or small drill?
