Rear Chain Adjusters - what thread size?
The two rear chain adjusters on my Dominator 99 (1957) have both broken off and will have to be drilled out. I've bought two beautifully engineered stainles steel adjusters to replace them from CPC Engineering (www.cpcengineering.co,uk) which I assume are the right thread.
Measuring the thread of the new 1/4 inch diameter adjusters with a thread gauge, with a view to tapping the holes out, expecting them to be 26 TPI (Cycle Thread or BSF), I found that they are actually 28 TPI which equates with 1/4 UNF, which seems a strange size for a British bike of that era.
Any ideas, not only on the sizes, but also on the practicalities of extracting the old adjusters which are broken off flush and have been like that for the past 50 years. I suspect they made be a bit harder than mild steel. I use 'Plus Gas' as a penetrating oil which is about the best in the business and I do have a set of 'Easyouts'..
The adjusters on my Domi are 1/4" x 26tpi. These adjusters are distinctly under-engineered and prone to breaking off. Some owners, on having an adjuster break, have fitted snail-cam adjusters instead. As for removing the broken off adjusters, easy-outs won't work. A pillar drill and patience are required, followed by Helicoiling or similar. All in all a guddle.
Is theswing arm in a finishedstateorcan you heat it? Ihave had success with "Eas-out's" (West German manufacture....) afterapplying heatand chill through thedrillingwith afreezer spray. I'mprettysure they were 26tpias I fittedsomespare bolts I had in the pot...
That's all very interesting thank you. Maybe the adjusters I have bought are not right with a 1/4 UNF thread. I'll take it up with the supplier.
As for getting them out. It is in a finished state and maybe snail cam substitutes would be a good option. Can anyone suggest any suitable ones or will I have to fabricate them from alloy or stainless steel.
The supplier concedes that they are 1/4 UNF (28 TPI) and supplied for a Norton Dominator. Maybe the later model were 1/4 UNF
I think you will find the steel used is not particularly hard just normal bolt (mild) steel. As they are broken off, it is most likely to mean they are as good as being welded in, as original attempts have sheared them, so I would imagine you'll have no luck with an extractor apart from snapping this off too, which would be really difficult if this snapped off flush as they are really hard metal.
I would attempt to drill them out.....Do this with ever increasing drill sizes from a small pilot drill size, but keep the maximum drill size just below the correct tapping size as you are likely to wander off slightly....Quite often when the hole you are drilling is getting near the correct size it will expose one side or parts of the thread as bits break away so at this point I would get a first taper tap of the correct thread and carefully wind this in gently in and out, after a while you may be lucky to get the tap going in and removing the original remains of the bolt, Procede until the rest of the old bolt flakes comes out. Finish off with a plug tap. I personnally would undertake this freehand as trying to mount this in a drill stand would seem near impossible. Remember they are quite rudimentary and don't require microscopic accuracy like an engine repair would.
If your endeavours destroys the thread you could Heli coil the thread or make up some adjusters with the next size up thread....no-one is going to notice and they'll be stronger too.
Les
Apparently you can buy left hand drills for just this job. So the offending article emerges automatically when its centre has gone. I'd be worried that the chuck might unscrew. I don't know how it is fixed on my mains electric drill.The prospect of placing a motorcycle on its end beneath my cheap pillar drill is intriguing.
Les
Very helpful. I have in the past managed some similar awkward jobs, but that's the challenge with these old bikes. I take your point about tapping out to the next size up too.
I'd still like to know if anyone has any experience with the snail cams suggested earlier because practically that is a good option, albeit not original looking.
I really must compliment the company who supplied the chain adjusters. I suspect they may be known to NOC owners already.. This is CPC Engineering which is near Redruth. I spoke to the owner and he said 'no problem I'll make some up in Cycle Thread (26 TPI) for you'. I then declared that the current adjusters will probably need drilling out if they did not come out cleanly they may have to be tapped out to the next size up and he told me to let him know what size I wanted and he would make some up in SS to suit . I don't think you can get better than that. Apparently he is used to making bespoke parts for motor cycles. Worth knowing. I'm afraid I did not clarify why the adjusters I received were UNC and in fairness the web site did say 28 TPI quite clearly, so apart from them being listed as suitable for Norton Dominator it was partly my own fault.
As regards the snail adjusters I think I have found exactly the right sort of part.
Another solution occurs to me if I fail with the type I am dealing with and that is the earlier Dominator (1952) had a different type of chain adjuster. One that had a plate on the rear end of the swing arm through which the threaded adjuster passed. More in keeping with the model and vintage of the machine than the snail cams.
I don't see them listed anywhere so they may have to be fabricated.
The early s/arm chain adjuster (I think the changeover is in 1957) needs a different fork end. This is formed by inserting flat steel into the end of the tube and flattening it. The axle slot is machined to an open end.
I like the snail cam idea. Let us know what cam you choose, and how you get on. Make sure you incorporate a means of adjusting wheel alignment.
I'll be starting next week. Starting with a drilling out which I hope will work and then to look at one if the other options.
There are quite a few solutions to this problems of duff adjusters in Featherbed Swinging Arms. Often the broken section won't budge and the end result can be a broken drill bit or extractor end adding to the problem. I like the cook and freeze idea to help free the broken end. Some people have soaked the threaded hole with Cola overnight and this has also worked.
I have played about with the problem in a number of different ways. Drilling out the stuck chunk has usually messed up the inside thread. If I was in a quick-fix hurry. My solution was to drill and tap an extra half inch of 1/4x26tpi Cycle thread. There is enough room to do this. I then found a bolt that was half an inch longer than the adjuster, file the head round, then ran up and threadlocked a nut under the rounded head. In essence just making a longer adjuster.
If you are thinking of a helicoil solution.Much easier, if you have the tools, is to drill and tap the old hole up to Commando size. Again there is room to do this. As the attachment shows the Commando adjuster is longer and much beefier. The only problem being the AF spanner size nuts.
adjusters-003-jpg
Thanks for your suggestions
Delighted to report that after persevering and using a lot of patience I managed to drill out the two broken adjusters and tap them out to 1/4 Cycle (26 TPI) in situ. for some reason they were unusually hard and good quality new colbalt HSS drills would not touch them and I resorted to a carbide tipped drill listed as a 'locksmiths drill and suitable for hard materials). (full carbide tipped drills are very expensive and brittle|) Using some lubricant at a moderate speed, with a power drill, once they had bitten and made some progress I was able to use ordinary HSS drills.
CPC Engineering in Redruth are very helpful indeed and run by enthusiasts. They are making up stainless steel adjusters for me with 1/4 cycle thread, instead of their listed adjusters which have a slightly different (28 tpi) thread. The quality of their stainless parts is excellent.
Many thanks for all the advice which was invaluable.
