I'm needing a complete set of engine/gearbox mounting bolts for my '50 Norton Model 7. My bike was a basket case when I bought. So, I have no mounting bolts/nuts at all. Does anybody sell a complete set for my bike? I've tried Norvil, but getting no response. I live in the USA, so I need to communicate thru email with supplier. Thanks Steve
Andover Norton have a very…
Hi Steve, Norton singles &…
Previously richard_evans w…
Previously richard_evans wrote:
Andover Norton have a very good reputation and I'm sure they would not ignore you.
Richard--Just received email back from Andover Norton and they don't supply these.. Just to let everybody know..Thanks for your help though.
How disappointing. The abs…
How disappointing.
The absence of responses may indicated they are like hens teeth.
It sounds as though you will either have to go hunting for used parts, check with one of the many suppliers of stainless steel fixings, or get hold of one of the very proficient engineers that exist in the UK who will make them up for you.
I came across a knowledgeable classic nuts and bolts man called Tim Kendall who might point you in the right direction sales@groveco.co.uk
Helpful engineering company CPC Engineering
If you manage to contact L…
If you manage to contact Les, at Norvil, on a good day, he can be very helpful. Unfortunately, good days seem to be few!
You could try contacting t…
You could try contacting these guys unless the ES2 bolts are the same, in which case buy them!
http://www.ebay.co.uk/itm/Norton-ES2-Plunger-Engine-Plate-Studs-Nuts-and-Washers-Stainless-Steel-1948-52-/112326242995?hash=item1a272a72b3:m:mGv22CtnAeEYN8cVCXz2weg
Previously Dan Field wrote…
Good find
Good find
I bought a set of these but the short engine plate-frame mounting bolts were 26TPI and should be 20TPI to screw into the frame. Check this out before purchasing.
Previously steven_allen wr…
Previously david_malcolmso…
Hi, try again! I spoke to Les yesterday afternoon. The secretary (Sue) is very knowledgeable, despite what she might say. Remember the time difference. I have a Model 7...great bike! David....PS look at Norvil website for ordering to get the part number and if in doubt Se or Les will sort you out.
Previously Skip Brolund wr…
Previously Skip Brolund wrote:
Hi Steve,
Norton singles & pre-featherbed twins:
Hello well I foundthat these Nuts and bolts are not has good has they make out, I had to replace all my base nuts on my Nortons has they were forever coming undone even with washers under them, I replaced them with Nooks Nuts there far better not had to touchthem since but you pays your money and takes your choice, yours anna j
Thanks for everybody's he…
Thanks for everybody's help on this issue. Problem solved. Thanks again. This is why I joined!! Steve
Please Google then as I have not mastered the art of attaching a link or pictures on this forum. (I wish someone would tell me or have some instructions somewhere on the site)
