Tappety noise from engine
I thought it was pinking at first and checked the timing which shows 31BTDC (Boyer) The plugs BP7ES if anythingI thinkare abit weak but not given it the chop test yet, I'm running a single new Amal with a 250 main, and 106 needle jet, No 3 slide with the needle on the bottom groove.
Valve clearances are good and were checked at the same time as the rest of the checks
I thought pinking just happened under load but I can hear this with the engine running under no load, it might be nothing except a "Commando Noise" that I've not got used to yet but what else couldI look at?
Bike starts and runs fine but this noise is on my mind all the time, any Idea's? I know it's difficult to arrive at a diagnosis without hearing it yourself but it might just throw up some idea's of what it might be.
Once I've done a plug chop I'll post some pictures of the plugs.
If it gets loud under load I would not run it,a bust rod is no joke. Big ends have been found out of round too.A new small end bush will need reaming ,sounds like a workshop job.
Read RH 296, pushrod location, sounds unlikely but it also happened to me.
Hi Robert, I've just joined the club and my first Roadholder was 297 so can't comment on any article in 296.
I've had a bit of an event that meant me havingthe Head and Barrelsoff again so all possible causes of the "clack" are being looked at.
Donald, ifyou are the Willy on accessnorton, looks like you sorted theproblem? Good one!
So how much clearance was there? Actually, I run a 3.5 slide on my single Mk2 Amal, that is on a 850 MkIII. Bennie.
Hi Mac. Not sure where you're looking or what you're looking for but Norvil list small end bushes (not bearings) as P/N 012100 for £7.54 ea. +VAT for all twins. RGM list itfor a Dommie asP/N T2160 for £6.90 +VAT. Haven't found it on Andover Norton's site yet.
Cheers, Lionel
OK on trying to find where the "Tappety" noise was coming from I was using a stethoscope but could not pinpoint it's source as it seemed to sound the same no matter where I listened. During the process I noticed the R/H exhaust had started to smoke and blipping the throttle pointed to things not quite right.Head came off and revealed pistons that were sloppy in the bores and a fair way out of servicable tolerences, how I built it up like this I'll never know my head must have been elsewhere.Anyway a +20 rebore with new style Hepolites have cured the clatter and I'm now 150 miles into the running in process.Currently running a new single MK1 concentric with 106/250 Jets and a No 3 slide with the needle on the top groove, Bike fires up easy and once warm ticks over nice and even but plugs still look a wee bit rich, another wee thing is that it occasionally cuts out as I come to a stop is it worth going for a bigger cut away on the slide? Pilot screw was set using a colourtune plug but could the setting of this be responsible for the cutting out?
Cheers, Lionel
Thanks Lionel
Sorry I've not replied sooner, as you can probably see it wasn't the small ends after all, just sloppy pistons, I gave up measuring the gap when it went out of tolerance, sounds a lot better now.
Mac.
Hi Bennie
Yes I'm the Willy Mac on the Access Norton site, the 3.5 slide might be the way to go, I'm still running in just now so I'm thinking a tad rich might be better than a tad weak?
Mac
Glad you got it sorted. Did you just replace the pistons and rings in worn bores so it was basically worn bores? It's made me wonder about my noises now! Best of luck with the running in.
One snippet I gleaned from a rebore specialist is that on Nortons (and maybe lots of others?) the bores wear faster than the pistons. So new pistons in a worn bore might not be the best way to go. Gordon.
Glad you got it sorted. Did you just replace the pistons and rings in worn bores so it was basically worn bores? It's made me wonder about my noises now! Best of luck with the running in. Hi Keith, if you read my post again you'll see it had a +20 rebore with new pistons and rings.
The difference in noise levels is like chalk and cheese!
It is considered better to have slightly rich mixture when running in as it burns rather cooler than a weak mixture. As an aside, a rich mixture burns faster than a weak mixture and so has a similar effect to slightly advancing the ignition timing. However, as it burns cooler, you don't get the associated pinking or detonation. End of aside. Gordon.
Yes I saw that, I should have said from the original rebuild. What was done to the barrels and pistons thenleadingto the onset of the noises?
Hi Keith
The engine was built up initially in 1987 and I ran it about for most of that year, but the oil return pipe fractured while on a bit of a fast run and lost all the oil.
The engine was stripped down and the crank rebuilt and balanced with two crank webs and standard secondhand rods.
I can't remember why I never re-bored it then, probably because it seemed to run ok, so when it went together again this time I never thought about checking the wear in the bores or on the pistons.
The rebuilt engine had good compression and ran with no signs of burning oil for 200 miles just the clackety noise, it was while I was trying to find where the noise was coming from that it started to smoke from the R/H pot, so that was when it came apart again and I found the bores and Pistons out of serviceable limits.
A Schoolboy error on my part for not being more thorough but it has given me more experience with the insides of the beast so all is not lost, just got to hope for some decent weather to get more miles on it now.
OK, running slightly rich will run a bit cooler, but on a proper rebore, is it really required? Like riding in a new Norton way back then, I would thinkjust keeping the load down the first couple of hundred miles would be sufficient?
Quite right Bennie. Whereas it's better to run slightly rich than slightly weak, it is of course far better to have the correct mixture. If you run very rich, there is the possibility of unburnt petrol diluting the oil in the bores. Not what you want.
I'm not running it rich on purpose it's just turned out that way from scratch. If you see my post about Amal Cutaway size you'll see I'm in the process of trying to get it just right.
