Is there a need for this shim (06-7646). I don't recall it being there when I stripped the motor down. I have got a new one to fit but am wondering if it is really needed. Your thoughts
They are to set the pressu…
This does raise the questi…
This does raise the question of how one decides how many shims are needed.
Previously john_holmes wrote:
They are to set the pressure the valve will open and fitted as required which could be 0 shims as does mine.
Covered by Mick Hemmings o…
Covered by Mick Hemmings on the engine rebuild DVD, from memory, which could be wrong, you remove shims or add them until the plunger can be heard rattling inside when you shake the valve, but check first. Its more likely add as mine rattles with none.
