MK1 850 Interstate needs MK11 Amal setup
Hi All
Can anybody give advise on setting up MK11 Amal single carb on the above, it's brand new and has thechoke leveron the top of the carb.
Thank You
Kind Regards
Mal
Previously malcolm_patterson wrote:
Hi All
Thank You
Kind Regards
Mal
Hi Mal,
I would think first change the pilot jet to #15 the needle jet and needle should be okay. I'm sure RGM might be able to advise you and supply any bits you'll need.
if its for an 850 you might find it will respond and carburate better with a couple off degrees knocked of the timing.
Dave
Hi All
Thank You
Kind Regards
Mal
Hi Mal,
Dave
Thanks Dave
Previously ian_soady wrote:
I would fit a cable and handlebar lever for the choke.
Thanks Ian
