vernier isolastic adjustment
Hello,
I have 'upgraded' my 850 Mk1 isolastic mounts to the direct replacement vernier types and am having a bit of trouble dialling out the vibrations, I have been backing out the adjusters as per the instructions and I am currently on front 3 holes backed out, and rear 4 holes backed out, which seems a lot more that the instructions would imply. Do I just keep backing out until things smooth out?
The original shimmed mounts vibrated a bit up to 2500 - 3000 revs and then things smoothed out beautifully.
thanks
Gerald
From the INOA Tech Digest (table 4-1, page/section 4-5)
Vibration up to 3k rpm
Front OK
Rear mount tight (remove 0.005")
3k to 5k rpm
front tight (remove 0.005")
Rear OK
0k to 5k rpm
Front and rear too tightHave you looked at the state of your Isolastic bushes?See also the discussion here https://www.nortonownersclub.org/noc-chat/technical4-commando-forum/876885284I certainly wouldn't keep increasing the gap, unless you are looking for a life-changing experience.Back in the day I found that 0.000" clearance (that is, no measurable clearance, just enough to allow the shim carrier to be rotated by hand) gave the best trade-off between handling and vibration control.I'll be interested to see updates, since I'm just about to install a Hemmings conversion on my current bike.
You have to be careful which replacement rubbers to use as some can be a lot harder than the original ones, one fix is to drill holes into the sides of the larger diameter rubbers. Would be good to know who does the softest MK3 rubbers as otherwise its best to keep your old rubbers and use the Mick Hemmings vernier conversion. I have only gone vernier on the front about 15 years ago and that did not change the vibration levels, they still switch off at 2500 rpm.
Cross check your settings with a feeler gauge to establish what you have actually got set. What type of head steady do you have? Do you have a Mk3 one piece rubber or the Mick Hemmings adjuster fitted to one side?
Hi Gerald
Have you added the the Mk3 spring tension mount to the head steady? It took a while to get it set right on my MK3, definitely worth persisting with.
Katherine
Dear Gerald,
Vernier adjustment is not all it seems, there is always some slack in the threads of vernier adjuster, when you adjust you have to have through bolt slack , when you tighten it don't be surpriseed when your clearance vanishes. check clearance with feeler gauges with through bolt tight and see what you actually have!, then adjust as necessary.
regards Martin
Vibrations when the isolastics are set correctly are more often than not the result of "pirate" rubber elements made to the wrong specification. This is known of the vernier type as well as the old type. Ask Norman White about his experiences with rubbers the customers had provided from questionable sources, or any other reputable Norton mechanic.
Thanks all, Let me answer a few of the questions.
The rubbers are new both front and back and are from reputable sources, I can not tell if they are harder than original.
The head steady is the std part-no: 06.5459, the box section one, This is also new as are the fittings for it. What was on there was the older open plate version.
As for measuring the clearances, for example on the front iso the adjuster is on the right hand side, which side do I slip in the feel gauge and is it between the ptfe washer and the end cap?
You measure between the PTFE washer and the outer end dish. It matters not which side you measure as the gap centralises. Once you have nipped up the main bolt, use a wooden lever to put some pressure sideways on the mount and then measure and re-adjust as required.
You are checking with the bike off the centre stand aren't you as this can be really misleading. I used to do mine on its wheels and with the prop stand blocked up and packing under the RHS footrest to get it as near level as possible. I always used feeler gauges even with the "vernier" (which are no such thing really) isolastics.
David, on this front vernier one it does matter as the left hand side is locked so there is no gap to get a gauge in( I forgot about that ). So with the right hand side now backed off 5 holes, I can just get a 0.006 gauge in the right hand side but not a 0.010 gauge. The manual mentions 0.010, but that is for the older shimmed type, may be I can still go there though.
I am measuring it between the ptfe washer and the end cap, on it's wheels and with the bolt tightened to 25 ft.lbs
Ian, what gap do you go to on your vernier type?
Hi Gerald, The centre iso tube should be able to move 0.006" (or whatever you set) between the two side caps. If you have fitted a Mk3 Isolastic 1 piece rubber to a Mk 2 850 you will also have to fit the Mk 3 mount as they are a different length.(or shorten it) The way to get away without this change is to fit the Hemmings modification which just replaces one end cap but uses the original Mk2 850 rubbers. What exactly have you got?
Hi Gerald, I no longer have the Commando but used to aim for .008".
I can't remember how many holes there are but ISTR 8. So backing off 5 holes should give you (5/8)/20 (assuming 1/2" UNF) which would give you over .030"...... One hole would give you just over .006".
Substitute numbers as required in my calculation but that looks far too slack.
Actually, it won't be 1/2" UNF as it's the thread on the mounting rather than the through stud we're looking at. So you need to see what the pitch of the thread on the mounting is.
Ian - you were correct as the through bolt is 1/2 x 20tpi CEI and the mounting is 3/4 x 20tpi - 1 full turn on the vernier adjuster is 50 thou so 1 hole is just over 6 thou
David, The front one is the RGM Norton Pre Mk III upgrade kit, This document on their web site has the details mk3_vernier_isolastic_instructions.pdf (look under tech tips)and it is their part number 050484C
Their notes also mention 1.5 holes or 0.006" I am backed out to 0.012, but I guess I will have to go back to 0.006 and try something else.
The rear was from Andover Norton.
imgp2135-copy-jpg
I have been using a Norvil "vernier" for 10 years now and with that 3/4" thread 4 to 5 holes gives me appx 008/011" depending where its measured. I also had the isos machined square a few years ago and the front had 060" taken off the RH to allow it to sit straight and cure the weave and pull to the left. A washer takes up the space on the LH. Torque is 25lbs/ft. My rubbers are quite soft but if i try to reduce to 006" the high frequency vibes return. So bearing in mind Andovers comment who knows what hardness of rubber is fitted. Certainly i can install them with fingers only but that could mean they are undersize.
