Stiff front fork
My roadster n/s front fork is very stiff so i'm dismantling to find out what the problem is.
I have removed the wheel and now need to unscrew the large chromium plated bolt at the top of the fork. What is the size of the bolt, 5/16 AF or Whitworth more likely?
Any idea what the cause might be ?
John
Check the mudguard/brace is not loading the legs against each other.Top and bottom yokes can be twisted in relation to each other
