I am trying to remove the pivot spindle from a 74 Commando swinging arm and following what I believe to be the manual instructions. Insert appropriate size bolt into the threaded end of the spindle and use a locknut to tighten down. From their wiggle and pull the spindle out??
It simply doesnât want to budge, I am not missing something here and the spindle is actually threaded into the arm or the frame is it?
It probably hasnât been previously removed so I expect it may be corroded in though I have had penetrant spray all over it (and into it!) for a week and canât get it to shift.
Anybody got any good ideas?
Thanks in advance
John
Previously john_dunk wrote…
Thanks for your response S…
Thanks for your response Steve. Yes, locking bolt out and I have been squirting penetrating spray in there
I recently replaced a swin…
I recently replaced a swing arm spindle on mine and needed a slide hammer to do the job. I bought a bolt of the correct thread to screw into the end of the swing arm spindle and welded a length of stud bar to the end of it. Then with a hefty piece of steel on the stud bar I was able to drag the swing arm spindle out. I would not have got it out without.
Where in the country are you - I'm happy for you to borrow my slide hammer if you can't get fixed up elsewhere.
Dave
Previously Dave Broadbent…
Dave
Hi Dave, that's a kind offer - I came to the same conclusion myself that a slide hammer was the answer and caught one on good old FleaBay before I saw your message. I had been thinking to get one anyway so hopefully it will do the trick! thanks again
Hi Just changed mine durin…
Hi
Just changed mine during a compleate strip down. Mine to was jammed solid, it took a 5lb hammer and a drift to knock it out from the other side. i posted a picture of it.
On plus side i was told that the bushes in the swing arm are very hard wearing, and they are i bought a standard size replacement pin and it is a sliding fit with no play.
You can buy over size pin but assume you have to ream the cradle.
Good luck.
Previously john_dunk wrote:
john have you removed locking bolt which bolts through in the middle of the swinging arm and locates the spindle or the two cotter pins as on a mk 3
steve
