Commando sprag gear
I have recently completed a full rebuild on the starter mechanism . Just lately the slipping has become more noticeable on starting . I am running a RGM belt drive is it possible the front alloy pulley has worn to which the sprag throws itself into. Just seems so strange after a couple of dozen starts. Has anybody else exprianced the same problems, the commando is a 78 MK111.
Kind Regards
Andrew
Hi Andrew,
What do you mean by slipping ? Does the starter just spin without any nasty noises or does it sip and make some nasty juddering ?
If you are running a belt, are you running it dry ? If so the sprag will not last long as it must run in oil.
Hi Tony,
The starter motor is a new 4 brush alton from Norvil, a new full power battery has been fitted. The starter spins fast and furious with a wizz so to speak and then i release the button and press again to try and get it to engage, it sometimes grabs a little then releases and then it grabs hold. But it has been progressively getting worse and i know in the near future it wont grab at all. I do run a dry primary drive belt can i run it in oil ? because when i mentioned it to Les Emery he seemed to think not, but i always thought when gears are involved oil springs to mind bit like in your gearbox.
Andrew
The gears in the gearbox are in constant motion, those in the starter drive train should only move when the button is thumbed... hopefully! So no comparison there.
It's the sprag clutch that needs the lubrication, general consensus is that running in oil is best, though I am surprised in this day and age that there isn't a grease (maybe from aeronautical background?) that would be up for the job.
As it's an RGM belt, what's their take on wet/dry running?
Sorry my mistake the belt drive kit was from Novil in the end. A bit of a story i had ordered one from RGM and after a long wait i got a refund and placed an order with Norvil, you hit 50 and the mind goes.
Like you say the sprag clutch needs lubrication its just the best way going about it, would grease be too heavy or PJ1 a chain lube be too sticky.
The answer i got from Les was why on earth would i want oil in there .
Does anyone else with a belt drive run oil in the primary drive casings.
Kind Regards
Andrew
I am not familiar with the alloy front pulley on a belt drive for the electric start. Are you saying that the sprag 'teeth' bear directly on an aluminium face and there is not a hard steel sleeve inside the pulley?
Perhaps you had best discuss it with Les and get his advice on making it work at its best.
Norm
Hi Norm,
Just stripped down well got the casing off etc and spun it over and its definitely slipping on the sprag then grabs when it wants too. It seems to me as if the sprag teeth are not throwing out completely.
Thinking back the front pulley is soft alloy inside i will have a look though.
The plot thickens and a chat with Les in his Happy Hour.
Kind Regards
Andrew
are the sprag bearings moving parts non magnetic. if not wouldnt the magnetism surrounding it have an effect on its operation.
Barry
The sprague is made from hardened steel and should run between a hardened journal and a hardened ring. Any alloy components will not survive first contact with the starter button.
Hi all,
As David pointed out the sprag gear, journal and the ring inside the front pulley are all hardened.
Having stripped down and a close inspection nothing looks untoward or worn. My take on it at the moment, the sprag gear was new with its packing grease applied from the factory and a new belt drive fitted at the same time. The fidres from the new belt have worked there way to the sprag gear and slowed down the gears from throwing out.
So what i have done clean down the sprag with WD40 and now got it soaking in Castrol 20/50 oil. I will get it rebuilt over the next couple of nights and see what happens.
Andrew
Kind Regards
Andrew
Hi Andrew,
Not a lot of point asking Les anything then. (Does he ever actually have a happy hour.) The reason you need to run oil in the primary chaincase is because there is a needleroller race in the middle of the sprag clutch When the engine is running this bearing is in constant motion at whatever rev's your engine happens to be running at, no oil in the case meansbearing runs dry, not good engineering practise. It is possible that the spragclutch device was not originallydesigned to start a Norton motorcycle engine as I believe the designers recommend running with at least 50% oil immersion.
Regards, Ian.
Andrew
Fitting a belt drive to a mk3 and running it dry WILL eventually destroy the starter motor. The sprag, needle roller bearing and the starter motor drivetrain all need the lubrication provided by the primary drive case oil.
what WILL happen is the sprag & needle roller will seize, locking the engine to the starter motor drive train, the starter motor is then subjected to a speed it cannot take and the rotor windings explode wrecking the starter motor.
The worse case is the starter motor seizes when your at speed,locks the engine and brings you off.
I consider it extremely irresponsible of the the supplier of your belt drive for a MK3 and not point out what will happen if you fit the starter mechanism and the belt is run dry
There have been quite a few posts warning of the perils of belt drive mk3s with the belt run dry. If you want to run a belt on a MK3 (with its starter) it has to run in oil.
I've just noticed that i have repeated what i said to yourself back in September.
Peter Shand
Hi ,
Thank you Peter and to all the other members for there support on this post. Luckily i have only covered about 100 miles or so before the weather changed and have been starting the bike up in the workshop. I will get the oil put in the primary drive before any more start ups.
Kind Regards
Andrew
Back Again, the belt i am running is a H T C and a H T D cannot run in oil as it swells and softens the teeth. I have just spoken to RGM for a bit of advice and they wouldnt give it as the belt drive was purchased elsewhere, so i rang happy hour and he is not back untill Monday 4-5 pm.
I have to find the pitch out 8 or 10mm of the belt and the difference between H T C and H T D . Hopefully the belt i have runs in oil has anybody came across this problem.
Andrew
Andrew
Hi Andrew, I was just looking through your posting as I am currently fitting a starter motor back to my Mk 111 commando which has a belt drive fitted to it and was looking for advice on how the gears, sprag clutch etc should be lubricated. Did you identify which type of belt can run in oil?
