Cam Timing commando MK3
Hi
I have just had my engine stripped all the way down as had an oil leak from the crank caseHalfs found out someone did not use any jointing compound on it at all. But I have now got Three bond for when it go`s back together.... now I have found it has got a Meagcycles 56000 07-07 cam in it. now the thing is do the cam timing go back as the standard cam setting or have they got a differant setting i need to do ? if anyone know can you please put me right on what I need to do.. as I bet there is some people out there that has this cam in there set up.
Thanks Maurice
Check out the megacycles cams web site there's a download catalogue with lots of info on the timings and clearances.
well after close inpsection of the megacycles cam it is no good as it is braking up on near all of the lubes... so I have ditched that and just ordered a PW3 Cam from AN so the full rebulid will start up soon. But I have all winter.
Previously Maurice_cloud wrote:
Just ordered a PW3 Cam from AN so the full rebuild will start up soon. But I have all winter.
Hi Maurice
I noticed that you did not mention your Cam-followers, when fitting a new cam you really should replace or have your existing followers refaced, If you want to give your new cam a decent start in life.
Best regards
Katherine Scott
Hi Katherine
yes sorry that I did not mention that but yes I am having themrefaced as a matter of course as don`t want to go down that road of replacing them and the cam again in a shourt time so thanks for the mention of them.
Maurice
