what cush rubbers fit my Electra can't find listing in spares list
Hi, If you go to the NOC…
Clutch rubbers
Good luck.
Mine were so thick and incompressible (made from plastic?) I ended up cutting sides away to get them in.
Terrible job.
Hi, If you go to the NOC Shop and select the Lightweight section, the 'Rubber items' and scroll down you will find these rubber inserts under part number 040386/7 at a cost of £7.50. For what it is worth I found they were incredibly difficult to fit because they have to be heavily compressed to slide into place. I found I had to lubricate them, slip the large ones in first then lever the small ones in. Good luck!!! Nick
