I have a 1971 commando, it looks like someone bolted something to the down tubes (photos attached).
Can this be repaired if so could you recommend anyone to do it?
I have almost stripped the bike down as I would like to get the frame powder coated.
I live in Milton Keynes but happy to travel
Adam
John hand is one of the best…
Probably crash bars - were…
Probably crash bars - they were never a good idea.
You can buy new frame sections from Andover Norton:
https://andover-norton.co.uk/en/shop-drawing/465/1971-on-commando-frame-repair-items
You could cut out the damaged sections and let in new tube from the AN repair sections. But it might be cheaper to find another frame.
Thanks, I am a bit reluctant…
Thanks, I am a bit reluctant to buy another frame as the frame engine and gearbox numbers all match. Hopefully I will find someone to repair it as I don't have the equipment or know-how to repair it
A frame guy should be able…
A frame guy should be able to heat that and pull it back into shape with a rod temporarily welded to it. And a bit of hammering. Maybe a smear of filler then.
John hand is one of the best frame makers I know - he's worth talking to - I only have a facebook link sorry.
https://www.facebook.com/profile.php?id=100050486261659
Dan
