Starter solenoid
Hallo,
I am Rik from Belgium. Currently I am rebuilding a Norton Electra that I bought in 2010 in boxes.
Lukely the year after I bought a complete one. So I have an example.
My question is : Can I use a starter solenoid from a Commando on my Electra?
Thanks for your response,
Rik
Just about all starter solenoids are the same, just a very heavy current relay.
But an anomaly will show up when you try to make any solenoid work on the Electra. All solenoids I have seen need a live supply to operate them from the ignition switch. On the Electra this was supplied from the original Wipac Triconsul handlebar switch. No Longer Available. The repro Triconsul even though it looks the same does NOT switch live out to the Solenoid. SO you will have to arrange a relay via the ignition to make this switch work, details on aoservices.co.uk
In reply to by ulrich_hoffmann
Hi Uli, I am looking for a set of standard or +0.010 thou Electra barrels to rebore to +0.020 thou to match my set of NOS pistons.  Would you have a set that I could buy?   If you do would you email me via the club system?   Cheers.  Nick
