000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
961 rack/carrier, straight through long pipes & de-cat
Can anyone point me to where I can get a rack to fit 961 SF? The bike has the split seat which has what looks like substantial mounting points (see photo) on the base but I can’t find any suppliers. I’d also like to fit de-cat & straight through pea shooters but the Norton ones are hideously expensive. Any help greatly appreciated. Seat base
Theil also produce the x-pipe replacement for the cat as well as the different pipes - not sure if they are any cheaper!
Bear in mind that you will also need to have the ECU re-mapped when the cat is removed and open pipes added.
For a rack, have you checked out Ventura? Alternatively if you just want a rack behind the seat, see if a Triumph rack would fit.
John
Roger from Ely had some short stubbies for sale ,don’t know if he still got em , I put the link on this site b4 a month ago
Privacy Policy
