I am rebuilding a ES2 1961.
It was in poor condition when I bought it.
I am now refitting the nuts of the swinging arm axle- the axle which is located in the frame. They were taken off for elecroplating and for repainting of the frame, the swinging arm itself was not removed from the frame as it seemed fit for purpose.
Now when I tighten the axle nuts and rotate the swinging arm up and down the axle nuts/shaft rotate with it.
I have tightened the nuts to 90 Nm torque - about 67 ft-lbs - and the arm in now difficult to move up and down. But the axle is still rotating.
It seems as though the inner spacers are too short to allow the frame gussets to clamp them.
Is there something wrong or should I tighten it more?
Any comments please.
Richard
Washers
Thank you Philip, I will try this.
Before the nuts were put on the shaft, there was no sign of unthreaded rod protruding from the gusset plates.
However, a number of turns of the nuts while up against the gussets plates were necessary, progressively becoming tighter. It could be that the frame was being pulled in and so the nuts reached the unthreaded part of the shaft.
Fitting washers
Hi Philip,
Fitting additional washers under the nuts made no difference.
-- the shaft is definitely seized in the inner tube, the shaft rotates with the arm
-- as the nuts are tightened the arm/shaft becomes progressively stiffer to rotate
-- this happens even when one nut is tightened with the other completely loose
-- when the nuts are tightened so much (90 Nm, motor car wheel nut tight!) that the axle cannot rotate in the frame, the swing arm can hardly be moved.
-- it seems that the rubber has stiffened so much that it is not flexing at all.
-- I am dreading having to remove the swinging arm from my newly painted frame.
Any advice anyone please.
On my B44 with silentbloc…
On my B44 with silentbloc swing arm bushes once the axle is torqued up the movement is all in the rubber in the bush, this normally fails by going soft and then disintegrating. As long as the stiffness is normal you look to be ok, wait for confirmation.
Further measurements
Thanks John,
Further measurements this morning show that the inner sides of the gusset plates have worn a hole.
The float between the gusset plate original surface is 6 thou.
The float when the inner bush goes into the hole is 31 thou, so the holes total 25 thou deep.
I don't know if this is important.
When I tighten the nuts so that there is just no float, the arm moves easily but the shaft is turning in the gusset.
As I tighten further the arm becomes more difficult to move, but the shaft is still turning in the gusset plate.
It requires 90 Nm to stop the shaft turning in the gusset, but then the arm can only slightly be moved up and down - with a lot of force. It can only be moved about 20 mm, but by forcing it very hard.
The only reason this that I can think is that the rubber has become solid.
Has anyone ever experienced this, and how do I correct it without a magic wand?
Further measurements 2
I have just redone all my measurements and have sat down to think about it.
The very high torque required to stop the shaft turning in the gusset is needed to pull the frame in to close the 31 thou gap.
At this point it is possible to move the arm up and down, easy with small movement and more difficult with greater movement.
By pulling the arm quite hard it is possible to move it about 100 mm each way. The rubber has deflected as it then pulls the arm back to the mid position.
I think it is ok as it is, it was the 90 Nm which worried me.
The frame hadbeen painted with the arm in place, I think the paint must have been binding when I first tried to move the arm.
Ideally I should remove the arm and close up these wear holes, but that won't happen.
Thank you all for your help.
Richard
I wonder if you're missing.....
... the spacer tube part H12-2/1090. This should stop the silentblocs moving inwards which sounds as though it's the problem you have.
The outer edges of the inner…
The outer edges of the inner bush of the silentlocs on the B44 are proud of the OD of both the rest of the silentloc and the swingarm so only the inner bush touches the gusset. On the BSA the swingarm is bored with 2 diameters so there is no need for a central spacer as there are lips on the ID to stop the silentlocs moving inwards. If your swingarm has a single ID with no lips then you need a central spacer to keep the 2 silentlocs a set distance apart or they will move and allow other parts to touch the gusset.
Outer Edges
Thank you John.
I have no reason to doubt that the layout is the same as that shown in the excellent frame exploded view which I have seen, and also as shown on the website of one of the reputable suppliers of this equipment, both of which show an inner spacer. Unless someone has really modified it earlier.
In any event, if the inner spacer is missing, I don't think that the problem symptoms would be as mine are - it would be too easy to move not too tight.
My problem was the recesses worn in the frame gussets leading to a very high torque needed to lock the inner shaft.
Richard
I would add washers to…
I would add washers to effectively bring the outer edges of the inner bush ID outwards on both sides, once torqued then the interfering part currently touching and causing the higher friction should have a larger clearance from the gusset and take the effort to more the swingarm to just deflection of the rubber. If the effort stays the same there are other issues at play.
The reason I suggested the…
The reason I suggested the missing spacer was that the gusset plates would then be pulled inwards to foul on the swinging arm itself. It's a bit like the QD rear wheel which needs the spacer to locate the bearings properly. In fact the proper layout should prevent the swinging arm touching the gusset plates at all hence would prevent the wear you mention.
I don't know how you can be…
I don't know how you can be so sure that the spacer is in there Richard, as you have not had it apart. Clearly something is amiss, and I would not proceed with the rebuild without correcting it. That means removing the spindle and bushes and replacing them, and repairing whatever has happened on the inside of the gusset plates. It is tightening up with that torque because you are in effect bending the plates/frame, which clearly should not happen.
If you had the frame/swinging arm assembly powder-coated, the heat involved would have destroyed the bushes. If it was wet-sprayed and oven cured, the same applies.
A cautionary tale for other restorers......
I’ve never had a problem…
I’ve never had a problem powder coating swinging arms with the metalastic bushes in situ, Maybe I’ve been lucky?
Dan
Well, that is my…
Well, that is my understanding, Dan. Notwithstanding that, there is clearly an issue here which needs resolving before the rebuild continues.
Like Dan, I have had several…
Like Dan, I have had several swinging arms powder coated with the silentbloc bushes in situ without any problems. My powdercoater confirmed that the rubber would not be affected during the cure. It depends on the cure schedule for the process and the resin system of the powder coat.
As with all we do with our restorations, check with the experts you are planning to use first and get their advice before starting.
Seized spindle
Richard,
I had this problem with my Slimline swinging arm. The spindle iss seized inside the silentblock bushes, so the only way for the swinging arm to move is to rotate the spindle in the frame gussets. This has then caused the gussets to wear on the inside, so that now when you tighten everything up it all locks together.
Really you need a new remove the seized spindle, which may mean cutting it out, which is not an easy job. When I did this I ended up having to replace the silentblock bushes as well. Unfortunately your paintwork is likely to suffer, but you've got to resolve the problem otherwise you'll cause even more damage to your frame.
Philip.
seized spindle
Hi Philip,
My Spindle is certainly seized in the bushes, but by torquing it so tight (90Nm) I have locked the Bushes right up against the gussets.
It is no longer turning and the movement of the swing arm (about 100mm up and down) is coming from the elasticity of the rubber bushes. (The further it is moved, the greater is the force trying to push it back to its mid position).
So it is doing the job intended.
The problem is that I have forced the frame in to lock the spindle, not good.
I know that I should fix it properly by taking it all out and repairing the recesses worn in the inside of the gussets and replacing the parts.
However, considering that the bike is not going to be used as a regular runner - more as a show bike, I am not keen to ruin the new paint job to get it back to perfect original condition.
I need to mull it over for a while.
Living in South Africa these spares are not readily available, they have to be imported. I found this morning that the piston rings I imported are the wrong size, they are too deep for the groove in the piston. So I am faced with getting the piston groove machined down. Where I live there is no-one who I trust to do it, so I will have send it away.
Our postal service is a joke, letters from Cape Town to Johannesburg take over a month, a letter from Germany to me took nearly seven months. I still have not received a small oil seal sent by Royal Mail in August. So it means couriering everything.
Sorry about all this, just letting off a bit of steam about all the little hurdles I am encountering.
Thank you for your advice.
Have a good weekend.
Richard
Richard - it sounds like you…
Richard - it sounds like you have sorted it. It doesn't matter if the spindle is seized in the bush since it is not supposed to move relative to the centre bush anyway. It is supposed to be as you have assembled it - the spindle locked tight to the frame plates, and the plates gripping the centre bush. The arm should ideally be somewhere in the middle of its travel when the spindle is finally tightened so the Silenbloc rubbers are relaxed when the bike is in use, and then the swing arm movement all takes place by twisting the rubbers. Just like those rubber suspension units often found in trailers. The centre bush stays fixed relative to the frame, and the outer bush stays fixed relative to the swing arm.
Drawing the frame tubes inwards should not matter - it's a bit like a part way stage in 'cold setting' a frame. The tubes already have high locked-in static stresses from manufacture, so I wouldn't concern myself with the bending stress since it does not vary constantly in use - so it won't lead to fatigue damage.
Thank you David, for…
Thank you David, for confirming that I think it is ok.
Regarding pulling the frame in, I was more concerned about bending the gusset plates or stripping the spindle threads. However it seems to have worked out ok.
Thanks to all again.
I've recently pressed out…
I've recently pressed out the two Clayflex bushes. No spacer. The bushes are 79mm long on the inner, I make it that a spacer would have to be around 55mm long. However, they took almost the full 10 tons to press out so the pivot pin end nuts could not have pulled the side plates in enough to squeeze the bushes in further. Without a spacer, and 'soft' fit bushes , the sides could easily pull in. There was about 4mm of inner bush showing when fitted, if that's normal (everyone ?) then you could inspect yours and see if there has been some pull-through.
Trying fitting a thin washer under each nut. It may be that the swinging arm bolt does not have enough thread cut on it and the nuts are becoming thread-locked. It may also be possible that the swinging arm has rotated in the past and actually cut a grove on the inside of the gusset plate. A temporary fix here would be a thin washer each side of the arm pending some weld filling and grinding.
