Model 50 18D1 distributor
Hi all, I am trying to determine the correct part number for the condenser in my 1963 Model 50. I know the points are "425219'. Can anybody confirm for me the correct condenser is "54410823" ? Pic attached below.... Thanks in advance. Clive.
As these condensors are either very old stock or probably pattern made god knows where I would fit a std car one on the outside of the dissy.
... or even remotely, hidden behind a panel. In theory it should be close to the points but in practice it makes no perceptible difference.
My current condenser works fine. Merely looking to have a spare on hand. Really appreciate if anybody could confirm the correct part number for me?
It does that. If you fit an ignition booster ,Boyer/pazon you can do without the capacitor and the points last forever and starting/running much improved.
