In the Oct 2010 roadholder mag there is an article by John Powellcalled bodging atin primary chaincase, in it there a is mention of a chap called Les Emery who makesmodified sliding disks wherethe gearbox shaft pokes out. Can any one tell me how to contact him.
many thanks Ian
here is the part number &a…
here is the part number & description from the Norvil website. Note that is the same part for commando, dominators, and singles ) :
060769 DISC - CHAINCASE SEALING - IN REAR CASE - PRE MK3 - PAIR 3.96
I just installed mine, you will get 2 tin pieces & a felt washer. They will need to be assembled in order & the correct direction so the felt washer is retained correctly. My original had 3 rivets holding the parts together, I spot welded my new parts together in 3 spots like the commando models did.
Let me know if you want pics of the new parts
Previously wrote: here is…
Hi lads thanks for the information and the offer of of some pics. it looks o/kIshould not have a problem,I have just placed an order.
many thanks Ian
www.norvilmotorcycle.co.uk
