Chaincase
In the Oct 2010 roadholder mag there is an article by John Powellcalled bodging atin primary chaincase, in it there a is mention of a chap called Les Emery who makesmodified sliding disks wherethe gearbox shaft pokes out. Can any one tell me how to contact him.
many thanks Ian
here is the part number & description from the Norvil website. Note that is the same part for commando, dominators, and singles ) :
060769 DISC - CHAINCASE SEALING - IN REAR CASE - PRE MK3 - PAIR 3.96
I just installed mine, you will get 2 tin pieces & a felt washer. They will need to be assembled in order & the correct direction so the felt washer is retained correctly. My original had 3 rivets holding the parts together, I spot welded my new parts together in 3 spots like the commando models did.
Let me know if you want pics of the new parts
Hi lads thanks for the information and the offer of of some pics. it looks o/kIshould not have a problem,I have just placed an order.
many thanks Ian
