Commando hub
Is a commando rear hub the same as a Dominator ??
many thanks Ian
Hi Ian - I'm surprised you haven't got an answer yet. Perhaps you should have posted it on the Commando section? The short answer to your question is "No" ! I'm not and never have been a Commando owner but I know that the early drum brake hubs (I assume that's what you mean) are slotted at the sprocket fixing locations to take rubber "cush-drive" pieces. (See pics on Andover Norton's site)
Dommie rear hubs are available new from RGM Motors. I bought mine a few years ago when they were only £29. I bought my new '99' pistons from Andover Norton in 2004 when they were about £90 a pair - now about £190 a pair! My motto now is "buy it when you see it" even if, like me, you won't be doing the work for a few years!
Cheers, Lionel
Hello yes you should off posted this on the commando page ? As it does not happen to be a Dominator Question ? The Answer is The early machine had the same hubs untill they where changed , for the rubber slotted type ? so what next??
