Does anyone know, what is the purpose of the paper washer between the bushes and can a substitute be fitted.
Pete
I believe that the origina…
Previously phil_hannam wro…
Previously phil_hannam wrote:
I believe that the original reason was to act as a barrier and so prevent electrolitic reaction between different metals. As modern seals are generally fully plastic/rubber coated this has made the paper washer redundant.
Thanks Phil, but what if I use the original seals?
I have not bothered with t…
I have not bothered with them for years...........and that is using both the old style or modern seals.
Just to stick in my two pe…
Just to stick in my two pennuth; if you have the forks stripped, you surely wouldn't assemble them with the old seals, would you? For the coppers they cost, I would always fit new seals, as I have never known them to seal again once removed. Stripping them out usually damages them, and anyway, they are old and hardened.
