P11 high level exhaust
Recently purchased a P11 "work in progress" project. The exhaust's are new and shiny. Unfortunately they are rubbish. Whoever made them obviously never tried to see if they fitted. So, the question is, who supplies the best? There are several suppliers, anyone got a view?
Jerry.
If my memory serves me well (!) I bought a pair of pipesfrom Armours well over 20 years ago. They weren't a perfect fit, but close enough.Once on though, they were as good as the day I bought them when sold over 10 years later...
Can't comment on the silencers as they came via the USA with (most of) the rest of the bike..
Try Walridge Motors in Canada. You could also try T.L.Wassell in England as they also make the exhaust pipes and the silencers. You will also need the long spacer, clamp, the G80CS type, small spacer, and the long bolt to connect it to the frame. The pattern exhaust pipes are not as the factory made them, as the factory cut them then bent them down. The factory type fit closer to the engine, but the pattern ones stick out a lot more. If you do not want to use the silencers you could always use Part No. 033277 in place of the silencers.
