I have stripped and rebuilt the primary side of my liquid cooled rotary engine. Now I need to adjust the clutch. Does anyone have a suggestion of how I can best do this. The procedure in the Commander is for a cable operatedclutch that doesn't work on my bike as it has a hydraulic clutch conversion.
With thanks to Richard Neg…
Should the system be bled…
Should the system be bled of any possible air before undertaking the adjustments?
With thanks to Richard Negus I have now been able to adjust the clutch on the rotator.
For anyone who has the same problem:
1) Remover cover and push the slave cylinder back as far as it will go.
2) Slacken off the lock nut.
3) Adjust the actuating rod using a screw driver so that it can just be rotated by hand.
4) Tighten lock nut.
5) Operate clutch a couple of times and recheck adjustment.
6) Replace cover.
