Hi
I have a 1972 750 interstate that was converted to roadster tank and sife covers.
I would like to know if there a different interstate tanks for different years, I would like to purchase a steel tank but want to make sure I know what to look for.
any information and pictures appreciated.
Andy
The correct Interstate tan…
The correct Interstate tank for a 72 would be Glass Fibre and best avoided, they then went to steel and there were 2 or 3 versions with the later ones being slimmer and with reduced capacity but not enough to matter. The tank will push you back about 4", but the footrests will be in the same position and that kills my hips so rearsets are a useful mod,
Previously john_holmes wro…
Previously john_holmes wrote:
Hi John
thanks for your reply,
do all the tanks fit the different year bikes.
So if I got the later steel tank would it bolt straight on without modification.
Andy
Previously Andrew Jarrett…
Previously mark_zenor wrot…
Previously Andrew Jarrett wrote:
An important point is that…
An important point is that the wider metal tank was made slimmer to reduce the tendency for knees to stick out in the wind and flap about at highway speeds thus making long distances uncomfortable.
Previously robert_percival…
Previously robert_percival wrote:
Hi Robert,
Thanks for the reply, I have purchased a metal interstate tank from the UK I do not know if it is the slimmer type that you mention here.
I will measure it once it arrives and post the dimensions on another post and hopefully someone will confirm what it is, with that said it will not change things only nice to know.
Andy
The Slimmer tank was used on the MK3 and was baffled, the early steel tanks are bigger and not baffled.
I have both tanks on my tw…
I have both tanks on my two 850 Interstates - larger tank on a Mk 1A and smaller one on a Mk 3 - and have just done some measurements. The top section of the tank with filler cap mounted on it , running from front to back , is slightly wider at the lower rear in the larger tank. If you measure across the width of the top section between the two edges and right at the bottom of the rear , just above the top frame tube recess , the larger Interstate tank is 22.5 cms while the smaller is 21.5 cms.
Otherwise you can fill the tank with water and measure the volume - the larger tank holds about 25 to 26 litres while the smaller Interstate tank holds about 22 litres.
Previously james_fanning w…
Previously james_fanning wrote:
Previously christopher_win…
Previously christopher_winsby wrote:
Hi
Thanks for tacking the trouble to reply,
I now should have enough info to work out what I have.
Andy
The tank arrived and it looks to be the later smaller version, it has a baffle plate and measures 21.5 cms across the bottom of the tank.
Thanks to all the people for your help.
Andy
Hi, The tank arrived and i…
Hi Andy
There are a lot of poor quality Interstate tanks for sale and it would be good to identify a quality replacement . My friend's Mk3 has is an awful replacement tank fitted, humped backed fat looking tank, with poor fitting leaking cap, the paint is lifting, and the brown sealer is breaking down and clogging the jets and so on.A few questions about your new tank, would you tell us who you bought it from,
is it finished painted or bare metal or primer,
is it the inside coated/sealed.
how is the fit and seal of the cap.
Are the threads correct for the taps
Are the threaded bosses for the mounting studs and security strap strong and in the in the correct positions
Best regards
Katherine
Previously Katherine Scott…
Previously Katherine Scott wrote:
Hi Katherine,
The tank is an original steel tank which I purchased from Ebay UK, the tank has various dents but that does not worry me as I repair my own tinware.
I was pleased to find that the inside of the tank very clean with no sign of rust or pitting, the price paid including postage to Australia was quite reasonable. These metal tanks are hard to find now and was offered a tank in perfect condition here but with a price to make your eyes water.
So with 4-5 hours work on panel beating I should have a nice tank that is a reasonable price.
Sorry I could not be of more help to you.
Andy
