mkIII right hand switch component wanted
Hi, on the right hand switch there is an 'off-on'off' lever, picture enclosed. Whilst the switch just about works, you can see the lever is missing the top part that causes the 'notch' effect, when you move the switch from one position to another.
I've tried the normal UK suppliers and these have been out of stock for 15 years, does anyone know if someone has one tucked away somewhere?
Greg
img_0598-jpg
Try www.Tri-corengland.com sparxs parts
they list the right hand switch gear at £70 plus vat
regards
