S type Commando question..
Does anyone have a picture of the way the loom is routed on an S type? (Early 70)
I have one of these new "Lucas" looms but it doesn't lend itself to sensible routing. I am not convinced it is correct.
Ta
The Lucas loom for 68-70 Commandos is originally thought for the Fastback models.
The wiring for the Zener diode is therefore not correct for an S type. On an early Fastback the diode sits at the left front of the side panel and not in the right hand sides aluminium footrest plate. Maybe this causes confusion?
I installed the Lucas harness also but I use a modern electronic rectifier module.
