Specifically the pipe from the oil tank to atmosphere. Is it directed down to the front end of the rear chain guard or elsewhere?
I'm getting conflicting information. I thought the standard arrangement was to the chain guard.
Thanks.
On my Electra...
Very neat Ian and far better…
Very neat Ian and far better than the original rubber grommet pressed into the hole in the chain gaurd that my Navigator had which the pipe simply threaded through!
Originally
Parts list suggests Breather pipe grommet 18285 in hole in Rear chainguard top portion 22342 accepts the end of Breather pipe 23430.
I use breather tube stocked by NOC shop and it seems to fit just right into chainguard without a grommet.
In use the breather tube gets full of creamy snot which I clear annually with a stiff cable pushed down the tube. Oh for an airline in the garage.
... it goes to the hole on the front of the chainguard from the rearmost of the 2 connectors on the oil tank. But I believe there is some variation. I'll be making an adaptor out of a 3/8 bolt to hold the pipe onto the chainguard as there's noting there at the moment.
