Dominator HT Pinion and Camshaft Woodruff Keys
My 1960 Dominator 99 (as far as I can tell) engine is coming together and most of the parts purchased for it so far have fitted fine.
Having noted the state of some of the existing woodruff keys, I decided to treat the motor to some new ones; the shafts and key slots all being in excellent condition. However the new HT and Cam keys do not fit. The new ones are deeper than the existing items; both of which appear to have had the peak of the curved part ground flat. Thus the new ones sit too high in the cut out for the slot on the pinion to go over. A picture where the new flank the old is hopefully included below.
There were some differences between suppliers over part numbers as follows:
NOC - 000572 Heavyweight Camshaft and HT Pinion. 065675 Commando Mk3 HT Pinion
Andover Norton - 065675 listed as also 000572 - HT and Camshaft pinion
Norvil - 000572 Pre Mk3. 065675 Mk3 Timing pinion but with use in Commando, Dominator and lightwieghts listed
RGM - 000572 Camshaft Pinion. 065675 Timing pinion, both listed as exactly the same size.
Being an impatient soul, I ordered two 065675 from RGM to get them the next day with the result noted.
My questions are:
1) Has anyone seen this before? Is there more than one size available for these items?
2) Are the 000572 items available in the NOC shop likely to be different in size?
3) Is grinding the key to size as appears to have happened to the existing keys acceptable or wise?
Many Thanks
Alan
Once upon a time you could purchase these keys as a set. I believe there were 5 keys in the set which cost a massive £2.00. In recent years I have obtained those for my needs as single items and generally found some fettling was needed for a snug fit. Often, on the larger keys, the ends also had to be chopped off so they dropped deeper into the crankshaft slots.
Hi Alan I too am building a 1960 Dommie 99 and, like you, have fallen foul of the ‘oversize Woodruff key’ issue. I ended up grinding and filing 3 out of the 5 keys to make them fit into the slots in the various shafts. I even bought a complete set from one of the usual suspects but they too were oversize. I think that’s what we get for now living in a time where precision isn’t particularly popular with the mass parts retailers.
Good luck.
Thanks for the responses. I don't understand why RGM are so precise about the dimensions of the parts if they are wrong for the job.
I would understand if there are variations from model to model, but the suppliers only mention the difference for the Mk3, while the parts appear to be the same size.
Phil, that set of five is now £7 plus VAT and carriage.
Maybe they were match fitted in the works? They need to be snug, and how quickly did the cutting tool stay within a tight enough tolerance to allow keys to be interchangeable? Remember...in car factories, "standard" pistons often came in four graded sizes...a, b, c and d. As the boring cutters wore, the bores on successive motors got smaller and they fitted the next size down the sequence until they ran out of sizes and reset the machine. You can always make a big key fit a small slot...it's a good thing they don't sell them under sized.
Before I put on my Big Boy Pants to buy my first Norton, I had a couple of Jap stinkwheel tiddlers. With the casual ignorance of Yoof, I ignored the fact that the woodruff key I had bought for the flywheel mag was a Very loose fit in the keyway (probably wrong key altogether), thinking doing up the nut at tight as I could would be fine. Then after a few weeks, that rattle just got louder......Eventually I could put it off no more: thankfully the crank itself was undamaged, but I had to get a new flywheel (and the correct key) from another dealer.....
I would not be too surprised to learn that the set of replacement keys for Dominators are now metric in size.
While there is no excuse as to why the keys supplied by the big suppliers don't fit, they don't have to be particularly precise in their size. They should only be there to act as a locator, and in many cases don't need to be there at all. That is why they are made from relatively soft mild steel.
If they are being relied on to provide the drive/power transmission, then something is wrong - there are things called drive keys for that job, a different animal as to shape and material. On our engines, that is what the tapers do/ should be doing.
Keyways for cam drives started to disappear in the car world from around 1985-86, instead relying on the shape of the bolt heads and proper torque to keep everything in place and that is the norm now in most engines made as cutting key slots and fitting keys costs time and money.
