Hi , I’ve removed the head on my 750 , while it’s off I imagined I should be able to turn the crank with a socket on the engine sprocket shaft and check bores , when I turn it locks at top of stroke ? when I turn back it locks when pistons have gone down , never done this work before am I missing something , I thought I would turn crank and the pistons would freely move up and down . Appreciate any advice,
Allan
Was it running ?
Was it running before you took the head off ?
If so, theres no reason why it should lock up. Can you turn it over with the kick start ?
Is the primary drive still fitted ? Could something in there be jamming ?
Other Possibles
I've had a Stellite foot fall off a follower and wedge a camshaft.
Flywheel bolt getting passionate with a conrod?
Something like a chunk of piston ring in a main bearing, across the drive pinion gears inside the oil pump or a timing chain problem.
An issue with the camfollower guide plate
Was running before , I’ve…
Was running before , I’ve got engine out on the bench , head off , barrels now off but it still sticks ? Doesn’t make sense ,
Ok, now spotted the culprit …
Ok, now spotted the culprit , I put the 3 inner chain case bolts finger tight into the crankcase holes just so I didn’t loose them !
the crank was touching one on its way round , No damage done as I obviously wasn’t trying to force anything, The reason I took head off is to investigate a oily left exhaust port , would this be the valve guide ?
Thanks for you replies
I assume the engine is in…
I assume the engine is in the frame, not in gear is it?
Allan - I suggest you start…
Allan - I suggest you start a new thread on oily left exhaust port
Thanks Tony , will do.
With the head off, the only resistance to rotating the crank will be the piston rings. Typically the greatest resistance is when the piston are halfway up (or down) the bore 'cos crank rotation here results in the greatest piston movement. At TDC and BDC you can usually rock the crank back and to very easily.
If your engine doesn't feel like this you should probably lift the barrel.
