slimline tank bolts
I found my tank bolts loose , appart from lockwire or threadlock has anyone come up with a better solution?
It happened a couple of times with mine. But I had not realised they can be spannered up hard and the tank threaded plate is still surrounded by rubber. It's not done it again. The two front slimline bolts are they same as the four used on prewar singles and the same applies. And they vibrate more. I don't feel the need to change the design.
