          Is it true that the rear wheel is offset in relation to the centre line of the frame?
if so by how much and why?
It's not true, both wheels…
Thanks for the info. Still…
Thanks for the info. Still leaves a question as to why the cradle would be offset.
To align the gearbox…
To align the gearbox sprocket to the rear wheel sprocket.
As John says, if yours are…
As John says, if yours are not then either it is the rear wheel offset or worse, the isolastic conversions put in the wrong way around. The later is quite common.
Thanks, I am still on the…
Thanks,
I am still on the original setup but hope to change to vernier this winter.
It's not true, both wheels are on the frame centreline. The cradle is offset to one side which maybe where the confusion comes from but the rim offset brings the wheel back in line with the centre of the frame.
