I'd be interested in how others get the rear chain properly adjusted with the plunger setup. I know that it's not the optimum design, being at its slackest in the normal laden position, so feel I should adjust it when it's on the stand and the suspension is fully extended. I set this at about 3/4".
What do others do? Edgar Franks is silent on this topic but the Haycraft book says to do it when the bike is on its wheels which doesn't seem quite right to me.
I am doing the chain…
plunger type suspension rear chain adjastment
As far as I know there should be no difference in chain tension in any position of the plunger suspension because it moves in a straight line unlike swinging arm which moves in an arc so adjust it on the stand to give the correct tension With swinging arm I check it by having the bike on its wheels with me sitting on it and moving it forward and checking the tension in different positions this is to allow for chain wear
But your 99...
... is a featherbed with swinging fork rear suspension. I was asking about plungers as the geometry is completely different, with maximum tension at the extremes of travel. Swinging fork generally has the maximum tension round about mid suspension travel (kinder to the chain & sprockets).
HI Ian, It sounds like my…
HI Ian, It sounds like my method (with the weight on the bike) should work. However With your design I would also check there is a small amount of slack with the bike on center stand (unloaded) and again with the suspension fully compressed using a good ratchet strap accross the bike . Once established that both situations give the same result (hopefully!) then the unloaded on the stand method is an easy and very convenient way to keep tabs on it. I have been adjusting my chain using a vernier caliper on both adjusters to get the sprockets in line as the chain run cant be seen on my bike and a bent frame at the front means if I line the wheels up the chain tension goes all over the place ! A small missalignment of the sprockets plays havoc with the adjustments. Its a Motoliner job.
Norton handbook
Norton's own handbook for 1947/48 says that for sprung framed models;
"track up the wheel and adjust until there is 3/8 - 1/2" up and down movement midway between the sprockets
NOTE.- It is important that this condition is obtained with the weight of the machine on the rear wheel"
and then I ask the good lady to hold the bike up as I check the slack. Job done
Thanks David.
I can't seem to find my copy of the manual at the moment but I do feel that given the geometry that method may result in a very tight chain at full bump / rebound.
I am doing the chain adjustment on my 99 today , I find the best way is to leave the bike on side stand and lay over the rear of the bike and reach down to feel for slack. The bike is lightly tied down on the ramp with a ratchet strap each side so it can't missbehave .I am having a tussle as the frame is twisted and I am having to compromise between wheels in line or sprockets in line .
