I'm going to attempt to make some metal fuel pipes for my 1935 Es2.What I need to know is what bore size should I use? It maybe a stupid question but if the bore is to small ,would and could it effect fuel supply.Thanks.Nick.
The fittings are 1/4" BSP.…
I used 8mm narrow bore cen…
I used 8mm narrow bore central heating pipe. That's 3/8" near as dammit. Cheap and plentiful.
The fittings are 1/4" BSP. Any normal soft copper pipe will be fine - not too thin-walled or it's harder to form. The greatest flow restriction will be in the nipples and the banjos.
The only bike that I can recall having a problem with 1/4" taps and fittings was the Triumph Trident but they can easily dip to sub 30 mpg with hard use.
